Newbie setup Gmocappy setup
11 years 3 weeks ago - 11 years 3 weeks ago #63620 by newbynobi
Replied by newbynobi on topic Newbie setup Gmocappy setup
It's hard to give you a hand, as you are very spartanic with your Infos.
net probe-in <= parport.0.pin-13-in-not net probe-in => motion.probe-input
Is in your hal file, does HalShow react if you push the tool sensor by hand?
Is parport.0.pin-13-in-not active when the probe is pushed or inactive?
Have you connected the gmoccapy toolchange hal pin in your postgui hal file, like mentioned in the documentation?
net tool-change gmoccapy.toolchange-change <= iocontrol.0.tool-change net tool-changed gmoccapy.toolchange-changed <= iocontrol.0.tool-changed net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
Norbert
Last edit: 11 years 3 weeks ago by newbynobi.
11 years 3 weeks ago #63627 by cncbasher
Replied by cncbasher on topic Newbie setup Gmocappy setup
i am currently looking at this , so bear with me , you are missing crucial parts from your files , i am in the middle of putting this together as i post this message
11 years 3 weeks ago #63628 by Stonefire
Replied by Stonefire on topic Newbie setup Gmocappy setup
Hi CNCBasher and Newbynobi
Thanks for your replies. Sorry if im not patient or precise enough. Just frustrated not getting further....
I thought all info was attached..
Going on vacation tomorrow, so I'll be back ....
Sincerly
Stonefire...
11 years 3 weeks ago - 11 years 3 weeks ago #63629 by cncbasher
ok give me a call soon as your back , and we can walk through it all
try these files , and let me know anything further , thats not clear etc , extract under your configs , and it will create a new config GMC
so seperate from your own , double check values just in case i have missed anything
Last edit: 11 years 3 weeks ago by cncbasher.
11 years 1 week ago #63943 by Stonefire
Hi CNCBasher
Thanks for your helpness and the attached files.
I've installed your attached files, but am uncertain how to check the change-function.
My g-code from Aspire looks like:
G21 G40 G49 G61 M6 T1
G17
M7
G0Z12.000
G0X0.000Y0.000S12000M3
G0X14.779Y5.923Z10.000
G0Z3.000
G1Z-0.325F25.0
G1X15.391Y-0.200F36.0
G0Z10.000
G0X14.779Y5.923
First time run it tell me to change to the wanted tool, but do not measure the toollength on the probe.
Can you help providing a g-code, with 2-3 toolchanges, so I can test the setup you've made?.
Looking forward to hear from you...
Sincerly
Steen
Denmark
11 years 1 week ago #63966 by cncbasher
attached demo , you should have it in your examples
Moderators: newbynobi, HansU
Time to create page: 0.369 seconds
