Newbie setup Gmocappy setup
- Stonefire
11 years 1 week ago #64050
by Stonefire
Replied by Stonefire on topic Newbie setup Gmocappy setup
HI CNCbasher
Here are the files you requested...
Sincerly
Steen
Sincerly
Steen
- cncbasher
- Thank you received: 202
11 years 1 week ago - 11 years 1 week ago #64054
by cncbasher
Replied by cncbasher on topic Newbie setup Gmocappy setup
ok thanks , i'm back home in about 2 hours , will look at it all then , if's thats ok
find attached modified ini file , give it a try in the meantime , it should now be the same as your origional
and it is in metric .
but beware you may need to change the section
[CHANGE_POSITION]
X = 25.0
Y = 100.0
Z = 2.0
these are mm so i would say they need changing as z should be just about at top of z for toolchange
so revise as needed .. and let me know
also in tool-length-probe.ngc
change g20 to g21 and try again
[CHANGE_POSITION]
X = 25.0
Y = 100.0
Z = 2.0
Last edit: 11 years 1 week ago by cncbasher.
- Stonefire
11 years 1 week ago #64211
by Stonefire
Hi
Are thes codes :
RS274NGC_STARTUP_CODE = G17 G21 G40 G43H0 G54 G64P0.005 G80 G90 G94 G97 M5 M9
changing anything regarding units. My CNC is running 1/10 of the speed it use to do....
to CNCBasher: Looking into your last post during today...
Sincerly
Steen
Are thes codes :
Sincerly
Steen
- Stonefire
11 years 6 days ago - 11 years 6 days ago #64260
by Stonefire
Hi again
Found the problem. The max_velocity was set to 1.00...
to: CNCBasher: It did'nt change anything. The cnc is going to 0,0 an trying to find the probe.....
Sincerly
Steen
Sincerly
Steen
Last edit: 11 years 6 days ago by Stonefire.
- cncbasher
11 years 6 days ago #64261
by cncbasher
i presume you are homing the machine , it has to be something your not setting
or you think you are and not . i'll take another look just in case
- Stonefire
11 years 6 days ago #64264
by Stonefire
Hi CNCBasher
Ok, Thanks. You got my files from last week. I have'nt change more than the Max_velocity, and added Backlatch setup...
Sincerly
Steen
Sincerly
Steen
Moderators: newbynobi, HansU
Time to create page: 0.211 seconds
