- Thank you received: 394
Newbie setup Gmocappy setup
- newbynobi
11 years 2 days ago #64485
by newbynobi
Replied by newbynobi on topic Newbie setup Gmocappy setup
Please check if G41 G42 or G43 are active?
If so execute G40 and G49 bevore starting the file.
Norbert
Norbert
- Stonefire
11 years 2 days ago #64486
by Stonefire
Replied by Stonefire on topic Newbie setup Gmocappy setup
Hi Norbert
Thanks for your reply, but how do I se if G41 G42 or G43 are active ?
The program, as you properly allready know, start with:
So the G40 and G49 are executed in the program....
Sincerly
Steen
; Gmoccapy_2_tools_with_compensation.ngc
; testprogram to mill two circles with cutter radius compansation
; and two different tools
; set the basic settings, this should be
; on every program the beginning
G17
G21
G54
G61
G40
G49
G80
G90
; get the first tool
T3 M6
G43
; go to center of the workpiece
G0 X50 Y50
G0 Z20
Sincerly
Steen
- Stonefire
10 years 11 months ago #65285
by Stonefire
Hi
Have'nt got anywhere with this problem ....... despite all the good surgestions....
Sincerly
Steen
Sincerly
Steen
- cncbasher
- Thank you received: 202
10 years 11 months ago #65288
by cncbasher
Replied by cncbasher on topic Newbie setup Gmocappy setup
are your paths correct and working ? i.e it's picking up the change.ngc macro etc
i,m wondering if it's a path problem
- newbynobi
10 years 11 months ago #65289
by newbynobi
If the change window pops up, than it should be OK.
Have you excecutet G40 and G49 in the MDI window prior to start the program?
Norbert
Norbert
- cncbasher
10 years 11 months ago - 10 years 11 months ago #65293
by cncbasher
try this ini file
Last edit: 10 years 11 months ago by cncbasher.
Moderators: newbynobi, HansU
Time to create page: 7.272 seconds
