GMoccaPy doesn't fit in 1024x768 resolution
10 years 4 months ago #75543 by RotarySMP
Hi Nobert,
Sent the last week playing around with gmoccapy, ngcgui, Andys Lathe macros (haven't got Features installed yet). I relly like the gmoccapy interface. Thanks for sharing that.
It looks like the default gmoccapy window is about 1000x768. Since debian has tool bar across the top of about 20 pixels, gmoccapy doesn't quite fit on my 1024x768 15" screen.
how can I either:
1/ remove the debian tool bar (F11 for a web browser)
2/ resize gmoccapy to about 1024x740 to fit the standard screen size?
Mark
10 years 4 months ago #75658 by newbynobi
Replied by newbynobi on topic GMoccaPy doesn't fit in 1024x768 resolution
Gmoccapy has a settings page, there you can configure the display types and sizes.
Please read the manual for details.
Norbert
10 years 4 months ago - 10 years 4 months ago #75805 by RotarySMP
Replied by RotarySMP on topic Which Lathe canned cycles for Gmoccapy?
Sorry about that. I had been in there and changed the resolution, but hadn't noticed the "Full Screen" option.
Different question, which lathe canned cycles generator is easiest to install in gmoccapy?
1/ NCGgui
2/ Features - Lathe
3/ Andy's Lathe MAcros?
4/ None are really working with gmoccapy?
Mark
Last edit: 10 years 4 months ago by RotarySMP.
10 years 4 months ago #75904 by andypugh
Replied by andypugh on topic Which Lathe canned cycles for Gmoccapy?
I don't know the answer to the question, but my lathe macros tabs are fixed-size and are likely not to fit anything other than Axis on my particular monitor.
I have tried to figure out how to make the tabs re-size properly, but haven't made much progress.
10 years 4 months ago #75935 by newbynobi
Replied by newbynobi on topic Which Lathe canned cycles for Gmoccapy?
All should work with gmoccapy, but as Andy mentioned, you may need to adapt some stuff.
I had no problems with features, not tested Andy's part nor NCGui, as I do use my own code, just as macros integrated in the MDI page, or some remapped code. But that part of the code, I am not willing to share, as it contains some major brain stuff and is not usable without proper documentation.
Norbert
10 years 4 months ago #76168 by RotarySMP
Replied by RotarySMP on topic GMoccaPy doesn't fit in 1024x768 resolution
Thanks for the feedback guys.
I used to use TurboCNC, and it had a very simple G77 canned cycle. Amazing how much lathe work that one simple cycle could cover.
G77 Turning/Boring/Milling Cycle
Function: Turning with multiple passes, infeeding by an amount set by the I word.
Syntax: G77 [repetitive axis] [infeed axis] [feed per pass] [optional feed rate]
Example:
G77 Z-1.250 X0.250 I0.050 F5.0
Notes:
The order of the operands defines the motion. The back-and-forth action will occur from the current position of the first axis on the line to the position specified. The second axis called out will eventually reach the position specified by feeding in increments of I each pass.
The sign of I is unimportant. Always use I for the infeed, no matter what other axes are being used.
Infeed is applied to the second axis on the line. Creative use of this command can be made for fly cutting / slab-milling or cutting deep blind slots on mills or trimming the edges of stock.
After each pass, the control "backs off" by 1 1/2 times the infeed. So if you're boring, make sure you have enough clearance for the bar.
If the infeed doesn't divide into an even number of passes, a small finishing pass will be taken.
I need to reactivate my old 7x lathe conversion and use it to try out different GUI's and see which works best for me.
Mark
Moderators: newbynobi, HansU
Time to create page: 1.200 seconds
