GMoccaPy doesn't fit in 1024x768 resolution
9 years 5 months ago #93629 by hwylie
Replied by hwylie on topic GMoccaPy doesn't fit in 1024x768 resolution
The suggestion of permanently mounted probe may be the way to proceed, if constraining machine use by the requirement to move to a fixed probe point, avoiding the danger of spindle traversing from work in progress over another job (or material in preparation) in order to probe - an infrequent scenario, although the large table lends itself to such.
It's anticipated that a single tool table can be used, provided that a custom fixture has associated coordinate system z-origin offset. Is this the direction of suggested investigation (having only briefly reviewed the suggested external-offsets github branch)?
Pointers to good examples of 'moveoff' or similar applications which move the spindle to fixed (G53) x-y coordinates of a probe following manual tool change, and return to G54 (or other) workpiece coordinates will be helpful.
Thank you, to both respondents.
9 years 5 months ago #93630 by andypugh
Replied by andypugh on topic GMoccaPy doesn't fit in 1024x768 resolution
Look at the sample configs, specifically sim->axis->remap->manual-toolchange-with-tool-length-switch
(You should be able to start and run if from the config picker, it won't try to move hardware, so feel free to experiment)
The following user(s) said Thank You: hwylie
Moderators: newbynobi, HansU
Time to create page: 0.287 seconds
