Annoncing gmoccapy 3.0
7 years 8 months ago - 7 years 8 months ago #125614 by Grotius
Replied by Grotius on topic Annoncing gmoccapy 3.0
Hi Norbert,
You have done a wonderfull job with your new release. I just did some wishes. I like your screenshot with the G40 offset's, it say's
a lot to me, but that was not the case a few month's ago.
Dxf2gcode is availible, just make some test with that and use it as filter for your work.
I am happy with dxf2gcode, i can use it, but it's to slow for my new type of machine. I need a conversion within 1 second's.
Just looking for the same property, only c coded, no google program coding style, with all respect for mr JT.
Part of the message is hidden for the guests. Please log in or register to see it.
The change to a robot based GUI is now as simple as building a plasma cutter??
I think yes. You can do it. And off course i will help you. If you need parts, i can cut them for you. And in Germany i know a
Thermal Dynamic's guy. He can also arrange part's for you. I am a good person, and i know when i can give parts for free.
Norbert, please test 64 bit Ethercat. It's the diamont of linuxcnc.
I have done some testings on the work Rene-dev has done
Is rene_dev the one that has tried to implement reverse speed with eo ? To implement the work of reverse-feed you have to be lucky...
Here you go : github.com/grotius-cnc/stable all fertig mont's ago finished. When i must do it again on next releases, I make spare time for maximum concentration while manual converting on github.
Last edit: 7 years 8 months ago by Grotius.
7 years 8 months ago - 7 years 8 months ago #126056 by chrisfairbrother
Hi Norbert, My wish : I really miss the “normal” terminal listing when browsing for a new file to machine in gmoccapy. I store my nc files remotely on a nas and I like to see the time/date stamp of the file I am about to machine especially when I have just re-postprocessed it.
Fixer has kindly created a modified iconview.py that I use that produces the listing I require. Link to Fixer’s post
forum.linuxcnc.org/gmoccapy/31746-iconview-filebrowser#82004
Keep up the good work.
Last edit: 7 years 8 months ago by chrisfairbrother.
The following user(s) said Thank You: Shu
7 years 8 months ago #126076 by Mike_Eitel
Replied by Mike_Eitel on topic Annoncing gmoccapy 3.0
Hi Norbert
I have not tested but a question.
I have not changed anything on your gui, but some adaptations in the hal's.
Do you expect that everything works after a simple upgrade to V3?
Mike
7 years 8 months ago #126107 by thadwald
Replied by thadwald on topic Annoncing gmoccapy 3.0
Can you please instruct me on how to get gmoccapy 3.0 on LinuxCNC 2.8 preempt?
7 years 8 months ago #126139 by Erikcnc
Replied by Erikcnc on topic Annoncing gmoccapy 3.0
I just download the files.
Try to install it my self allso for my new lathe.
There is a file in docs with a installation guide if i'm not wrong.
7 years 8 months ago #127053 by newbynobi
Replied by newbynobi on topic Annoncing gmoccapy 3.0
No, no installation doc, as you will need to run it rip-environment.
Just get the mentioned branch and compile as usual.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.538 seconds
