Spindle ccw hanging
11 Mar 2019 23:17 - 11 Mar 2019 23:18 #128401 by Grotius
Replied by Grotius on topic Spindle ccw hanging
If it was S0 (spindlespeed zero) the hal pin's would change in ccw direction.
So that is not the problem. B)
If user make a simple axis auto config to test m4. What is user's output?
Last edit: 11 Mar 2019 23:18 by Grotius.
11 Mar 2019 23:21 #128403 by biqut2
Replied by biqut2 on topic Spindle ccw hanging
One odd thing I notice is that it is showing S550 and the reverse button.
When I try it here, it shows S -550 for reverse.
Do you have a minimum speed configured somewhere? (I see that the bottom number on the slider is 550)
I am wondering if, because -550 is less than 550, the GUI is refusing to command that speed.
You sir hit the proverbial nail on the head! Thank you, my .pref file had a minimum rpm of 550 which is the slowest speed on my spindle. I changed the minimum to -3800 and its works like it should now.
The level of support here on this forum is second to none, thank you again for the fast response and patience!
11 Mar 2019 23:29 #128404 by Grotius
For accuracy check your pins. If it changes from cw to ccw at m4 with S0.
11 Mar 2019 23:31 #128405 by biqut2
It does, watching it in halshow all the pin states change accordingly.
11 Mar 2019 23:47 #128407 by Grotius
Okey, that is nice.
Can you redefine your exact problem in a few lines included with the solution at the end of this post.
Thank's. And power up the system. CCW full speed now !!!
12 Mar 2019 00:11 #128408 by biqut2
Okey, that is nice.
I edited the original post and title to include the solution to the problem. I hope this is an acceptable format of posting the information.
12 Mar 2019 14:42 #128439 by andypugh
Replied by andypugh on topic Spindle ccw hanging
You sir hit the proverbial nail on the head! Thank you, my .pref file had a minimum rpm of 550 which is the slowest speed on my spindle. I changed the minimum to -3800 and its works like it should now.[/quote]
I think this looks like a Gmoccapy bug. The minimum speed setting should still allow reverse rotation.
12 Mar 2019 17:23 #128455 by newbynobi
Replied by newbynobi on topic Spindle ccw hanging
I will check on this, but IMHO CCW shoul have negative values, i need to check if the settings page does allow negative values.
If this is a bug, be sure it will be corrected very soon!
Norbert
12 Mar 2019 17:33 #128456 by andypugh
github.com/LinuxCNC/linuxcnc/blob/master...py/gmoccapy.py#L3350
Maybe
        elif abs(real_spindle_speed) < self.min_spindle_rev:
            real_spindle_speed = copysign(self.min_spindle_rev, real_spindle_speed)
16 Mar 2019 16:55 #128753 by newbynobi
Hallo @all,
I checked with
gmoccapy 1.5.9 from linuxcnc 2.7
gmoccapy 2.3.5 from master
gmoccapy 3.0.2 from my development branch
All do work as expected, if you set a min spindle rev to 500 rpm on the settings page and than change to MDI mode and enter
S100 M4
you will have a spindle running reverse with 500 rpm and label shows S -500
enter S100 M3
you will have a spindle running forward with 500 rpm and label shows S 500
IMHO in the case mentioned here, it has had another reason, that reverse did not run. May be spindle.speed-out is not accepted by the VFD, as that value is negative, many VFD need absolute values to work properly.
So in short, I am not bale to find an error in gmoccapy code.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.274 seconds
