Debian 10 Dependencies
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
09 Jul 2019 11:17 #138960 by BigJohnT
Debian 10 Dependencies was created by BigJohnT
I was trying to build LinuxCNC on Debian 10 and gscreen and gmoccapy depend on python-vte but it is no longer in Debian or is it only gscreen and you use gscreen as your base?
JT
10 Jul 2019 02:25 #138993 by pl7i92
Replied by pl7i92 on topic Debian 10 Dependencies
isent it a little early to get to Linuxcnc 3.0 Debian 10
as it is 2.8 not published jet and Debian 9 will be on for some time
10 Jul 2019 05:13 #138997 by fixer
Replied by fixer on topic Debian 10 Dependencies
I got it running in simulation mode on latest Raspbian Buster yesterday.. VTE is not referenced anywhere in gmoccapy.py, so you can delete the "import vte" line.
I also had to disable "player" widget, I didn't bother with it since I dont use sound effects in gmoccapy.
The following user(s) said Thank You: BigJohnT
  • BigJohnT
  • Administrator
  • Administrator
10 Jul 2019 05:18 #138998 by BigJohnT
Replied by BigJohnT on topic Debian 10 Dependencies
I'll let Norbert do that...
JT
The following user(s) said Thank You: ikkuh
11 Jul 2019 01:32 #139068 by newbynobi
Replied by newbynobi on topic Debian 10 Dependencies
I just pushed a fix to 2.8 branch. I removed the unused import statements pango and vte. The player si still there, but should not cause a crash if gst is not installed.
release is now 2.3.5.1
Norbert
The following user(s) said Thank You: BigJohnT, tommylight
  • Hakan
  • Platinum Member
  • Platinum Member
20 Jul 2019 09:33 - 20 Jul 2019 09:34 #139968 by Hakan
Replied by Hakan on topic Debian 10 Dependencies
I can not get past the dependency on python-gtksourceview2.
It is depreciated as far as I can tell.
Last edit: 20 Jul 2019 09:34 by Hakan.
29 Oct 2019 18:57 - 29 Oct 2019 19:11 #149083 by pevlabs
Replied by pevlabs on topic Debian 10 Dependencies
Hello, I too may have boarded early on the Buster train. New custom built Ryzen AMDGPU hardware, Fresh Debaian 10 install. Added the RT Kernel. Need dual YY homing and believe that is rolled into linuxCNC v2.8. Set stanza up to grab:
deb buildbot.linuxcnc.org/ stretch master-rtpreempt
Can not get past the same dependencies.
The following packages have unmet dependencies. some of which exist but I have new versions:
linuxcnc-uspace : Depends: libboost-python1.62.0 but it is not installable
Depends: python-gtksourceview2 but it is not installable
Depends: python-vte but it is not installable
Recommends: hostmot2-firmware-all but it is not install
Is it best I wait for 2.9 to be added to buildbot or track down a manual install and try to do a little --force install magic?
Super thanks in advance for any guidance.
Brian
Last edit: 29 Oct 2019 19:11 by pevlabs.
30 Oct 2019 07:11 #149157 by newbynobi
Have you tried the sid one for python gtk sourceview?
SID Python-gtk-sourceview
python-vte is not needed for gmoccapy, but for gscreen!
Do you need to use debian buster? I do use MINT 18.2 actually.
Norbert
30 Oct 2019 09:11 #149174 by pevlabs
First, Thank you for taking the time to respond. Secondly for those landing here from a web search as I did I want to say I have been using linuxCNC 2.6 wrapped into Ubuntu for several years and its rock solid. My issues arrives from me developing a machine for a user base that will need v2.8 or greater (skipping 2.7) and already have a heavy Debian OS install base in their enterprise with new systems becoming the norm. So mostly it is up to me to figure this out, I am in no way unhappy with this awesome product.
Norbert,
Currently I have another a partition set with linux mint 19.2 and ran into the some install issues there too. I wrestled with it for a couple of nights with a manual kernel compile and linuxCNC compile. In the end I won but was hoping the all new and shiny Debian install would be more seamless and work with buildbot. I will do as you suggested for python tonight and see if that gets my past the three dependancies.
Thanks again.
Brian
01 Nov 2019 08:50 #149360 by andypugh
Replied by andypugh on topic Debian 10 Dependencies
I have built a working LinuxCNC on the Pi under Raspbian Buster, so it can be done. I can't remember what I did about the dependencies, though.
Does installing the ibboost-python-dev package help?
Moderators: newbynobi, HansU
Time to create page: 0.134 seconds
