Debian 10 Dependencies
05 Apr 2020 00:33 - 05 Apr 2020 00:34 #162730 by phillc54
Replied by phillc54 on topic Debian 10 Dependencies
Try the Stretch repository, they should be OK. Stretch Backports may have something later.
Last edit: 05 Apr 2020 00:34 by phillc54.
The following user(s) said Thank You: CNCFred
05 Apr 2020 06:07 #162744 by CNCFred
Replied by CNCFred on topic Debian 10 Dependencies
If you have all the dependencies you might try a build-bot installation.
Worked for me on debian 10. Advantage apt-get update for linuxcnc possible.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
05 Apr 2020 12:19 - 06 Apr 2020 04:38 #162763 by BeagleBrainz
Replied by BeagleBrainz on topic Debian 10 Dependencies
I tried for an experiment, to build those packages for Buster from Stretch sources, builds completed successfully.
One thing that maybe an idea is to use apt-hold to mark the packages mentioned by phli so they are not upgraded. I know this works well when using apt or apt-get to do upgrades.
Can report back that everything went smoothly with the packages I built from Stretch sources for Buster, and the install of Linuxcnc went ahead smoothly. I did mark those self built packages as hold so as not to be updated. Mind I did download and install manually.
Could the packages needed (once built against Buster) be placed within the buildbot repo ? Theoretically that should pull everything in with one go.
Last edit: 06 Apr 2020 04:38 by BeagleBrainz.
05 Apr 2020 18:14 #162783 by CNCFred
Just in case a link to linuxcnc buildbot
Buildbot 2.9
  • BeagleBrainz
  • Visitor
  • Visitor
06 Apr 2020 04:39 #162850 by BeagleBrainz
Well the buildbot main page. Thought that was a bit better than just a bump.
27 Apr 2020 11:48 #165803 by andypugh
Replied by andypugh on topic Debian 10 Dependencies
(I haven't really had time to look at the forum for the last month)
That is a possibility. You can see that we already back-port some packages on the main repo to provide dependencies to Wheezy.
www.linuxcnc.org/dists/wheezy/base/binary-amd64/
Moderators: newbynobi, HansU
Time to create page: 0.119 seconds
