gmocappy clock
5 years 8 months ago #200466 by newbynobi
Replied by newbynobi on topic gmocappy clock
How do you count parts?
Load a file = reset parts to zero
Every push to play counts one part?
Norbert
5 years 8 months ago #200474 by jasen
Replied by jasen on topic gmocappy clock
on all fanuc's usualy the part counter counts till you load another program or turn off the system , so yea , every program end increase the counter.
5 years 8 months ago #200712 by nonkeldw
Replied by nonkeldw on topic gmocappy clock
Sounds good!
5 years 8 months ago #200731 by newbynobi
I made a glade panel to be embedded in gmoccapy showing
Total run time
Spindle time
Cycle time
I will post this asap, may be I can add to that panel also the part counter.
All values are saved in a file and restored after loading the panel again.
Norbert
5 years 7 months ago - 5 years 7 months ago #201002 by newbynobi
So here are my glade panel, embeded in gmoccapy
First one is embedded in box_custom_4 and second one on the settings page, undocumented location B)
To use this, you need to download the attached files
timer.glade
timer.py
timer.hal
and place them in your config dir.
Then in your INI File in [DISPLAY] section add:
EMBED_TAB_NAME = timer EMBED_TAB_LOCATION = box_custom_4 EMBED_TAB_COMMAND = gladevcp -x {XID} -u timer.py -H timer.hal timer.glade
or:
EMBED_TAB_NAME = timer EMBED_TAB_LOCATION = ntb_setup EMBED_TAB_COMMAND = gladevcp -x {XID} -u timer.py -H timer.hal timer.glade
depending on the locatiopn you want the panel.
As I have been ask to add also a part counter, I will do that asap, meaning it will take some time.
Norbert
P.S. Hope nobody sees the new sliders with touch screen support, as I am still testing on them :whistle:
Last edit: 5 years 7 months ago by newbynobi.
The following user(s) said Thank You: biqut2, tivoi, HansU
5 years 7 months ago #201016 by biqut2
Replied by biqut2 on topic gmocappy clock
Thank you for this nice addition. It will help keep track of my maintenance schedule on my machines.
Moderators: newbynobi, HansU
Time to create page: 0.172 seconds
