white screen lockup after configuring 5th axis.
13 Jun 2021 23:34 #211976 by sliptonic
I've been running gmoccapy for years on a mill configured with a rotary 4th axis. Display is a 1024x768 touchscreen.
Today I started configuring a 5th axis. Duplicated the 'A' axis sections in .ini and .hal files for the new 'C' axis. I changed all the pins appropriately.
Now when I try to launch, I get no HAL errors but gmoccapy hangs with a mostly white screen. One part of the 3D view appears but no other controls. Everything is unresponsive. I had to ssh in from another machine and kill the running processes manually.
Any idea what could be happening here?
14 Jun 2021 05:39 #211998 by cmorley
Is there any clues in the messages from the terminal?
14 Jun 2021 17:06 #212037 by sliptonic
Replied by sliptonic on topic white screen lockup after configuring 5th axis.
Nothing at all. Normal log stuff of startup but no errors or warnings.
14 Jun 2021 20:28 - 14 Jun 2021 20:29 #212056 by newbynobi
Replied by newbynobi on topic white screen lockup after configuring 5th axis.
Very strange, please share your config folder.
Seems you are working with master,?
Last edit: 14 Jun 2021 20:29 by newbynobi.
14 Jun 2021 21:39 #212060 by sliptonic
Yes. Just built from current linuxcnc master.
My config is here. (master branch)
github.com/sliptonic/millstone
16 Jun 2021 17:36 #212208 by sliptonic
Any suggestions on how I can get more clues?
16 Jun 2021 23:52 #212237 by cmorley
can you post the terminal output?
17 Jun 2021 15:14 #212279 by sliptonic
attaching the terminal output. This shows both startup and shutdown after I killed the process.
18 Jun 2021 03:16 #212307 by cmorley
does a four axis screen work?
18 Jun 2021 15:44 #212341 by sliptonic
Yep, works perfect.
Moderators: newbynobi, HansU
Time to create page: 4.608 seconds
