Back or front tool
5 years 2 weeks ago #222986 by john11668
Replied by john11668 on topic Back or front tool
Compicated ? or impossible ?
If complicated then a few pointers might be nice
5 years 2 weeks ago #223053 by andypugh
Replied by andypugh on topic Back or front tool
Do you actually have both front and back toolposts?
One workaround is to program one toolpost in negative X. it's a bit of a kludge.
5 years 2 weeks ago - 5 years 2 weeks ago #223191 by john11668
I do have two toolposts (see pic on page 1 of this thread)
It was my intention to operate generally in Back tool mode but to use front tool for parting and screwcutting.
It wouldn't be a hardship to go back to parting at the back , but there are advantages for RH threading to operate from the front.
So my threading code is
G76 P1.5 Z-12.5 I-0.001 J0.1 R1.2 K 1.85 Q0 H3 L0,
My start point is is specified in a prior line
G0 X10 Z10
So presumably I need to make my start point X-10 Z10 ?
I take it I would then have to specify the offset for the threading tool to take it it X-10
I am struggling to get my head around whether to also make the K value negative (-10 - (-8.15))  (nom diameter less minor dia) would give me K -1.85
Will take courage in both hands and give it a shot , with one hand on the red .button
Last edit: 5 years 2 weeks ago by john11668.
5 years 2 weeks ago #223195 by john11668
Right , ! so I tried this .
System will not let me call up a K value less than J value and J value can not be less then 0 .
Without changing K value I cant seem to get it to work in reverse X
5 years 2 weeks ago #223331 by andypugh
Not a solution to the problem, which looks like it needs working on, but perhaps you could use an inverted back tool for threading?
5 years 2 weeks ago #223424 by john11668
I can do that indeed Andy.
Trouble is that it tends to lift the saddle . May try doing all from the front!
Just a shame there doesnt seem to be a solution otherwise .
Moderators: newbynobi, HansU
Time to create page: 0.101 seconds
