Back or front tool
5 years 1 day ago #224791 by rider-83
Replied by rider-83 on topic Back or front tool
I have the 160TCL and had the same issue with switching the spindle DC motor direction with M3 & M4. It was easily resolved with a polarity reversing module which I bought from a model railway supplier.
I can have a look at how I did it and send you the .hal example if you are interested?
The following user(s) said Thank You: john11668
5 years 1 day ago #224803 by john11668
Replied by john11668 on topic Back or front tool
Thanks Rider and and yes please .
I think I have the kit to actually reverse the polarity . I have been doing it manually with a 2 pole changeover switch and have set up a relay to do the same . I think I just need the hal entries to make a chosen pin operate one of the relays on a small board which in turn will energise my reversing relay,
Still interested to see your setup as well though.
5 years 10 hours ago #224871 by andypugh
Replied by andypugh on topic Back or front tool
linuxcnc.org/docs/2.8/html/man/man9/moti....html#SPINDLE%20PINS
spindle.0.reverse - TRUE when the spindle should rotate backward
5 years 10 hours ago #224876 by john11668
Fine but is that all that i need to add to my hal .
Somehow I suspect not
Please remember Andy that I am a novice here
My Hal was generated by initially by stepconfig and although I have progressively added a number of functions I have not needed to alter the spindle commands so i am floundering here !
5 years 9 hours ago #224878 by andypugh
Which output pin (if any) is connected to your reversing relay?
Is it safe to reverse with the spindle on?
5 years 9 hours ago - 5 years 9 hours ago #224879 by john11668
Was planning for 14 or 16 unless you advise otherwise
Would not be safe to call for M4 if spindle running under M3 and Vice versa .
Was planning to call for a pause but if that can automated then all the better
Last edit: 5 years 9 hours ago by john11668.
Moderators: newbynobi, HansU
Time to create page: 0.062 seconds
