Back or front tool
4 years 11 months ago #225574 by john11668
Replied by john11668 on topic Back or front tool
Please bear with me .
It looks like I may have been supplied a relay board which requires 9v to operate .
Will try to sort this out and come back again
4 years 11 months ago #226039 by john11668
So am now back to "round off"
And to apologise for consuming the time and efforts of all those who contributed .
It did turn our that my relay board was a wrong un,  So I wasted a lot of my time and effort trying to make it work (and a lot of time and effort from you guys trying to resolve my problems )
One problem was that as with all stuff from Ebay  the instuctions are non existent .
It took quite a bit of research to discover that this board ( while having an input requirement of 5-24 v ) needed a 12v  input  , a minimum of 9v  so was just not going to respond to a 5v pin signal from a parallel port .
And all these  boards look the same , so with the absence of instructions it is easy to be mis-led
All was not lost though.. The advice on the Hal formats to permit the correct signals to be created at the pins  (and inverted ) has been invaluable .
I have moved another couple of steps forward with front and back tools ,   and got spindle reversing working  , so without adding a turret I am reaching the limits of the capabilities of this machine  . Need to play now  and make some  components and some chips
Thanks again guys !
Moderators: newbynobi, HansU
Time to create page: 0.187 seconds
