Spindle Load feedback in Gmoccapy
3 years 10 months ago #258756 by HansU
For getting the Glade catalog for Gtk2 (LinuxCNC 2.8) working, following needs to be done:
First check with
pkg-config --variable=catalogdir gladeui-1.0
the directory of the glade catalog.
For me it was
/usr/local/share/glade3/catalogs
Then get the "lib/python/gladevcp" directory from the source code repository ( github.com/LinuxCNC/linuxcnc/tree/2.8/lib/python/gladevcp )
and copy all files from that directory to the above mentioned directory.
For example
git clone -b 2.8 https://github.com/LinuxCNC/linuxcnc.git --depth 1 cd linuxcnc/lib/python/gladevcp sudo cp -r * /usr/local/share/glade3/catalogs
This worked at least for me for glade-gtk2.
The following user(s) said Thank You: blazini36
3 years 10 months ago #260105 by piflixe
The new spindle_load bar posted above works for me. Thank you!
Still no success in setting up glade unfortunately.
3 years 10 months ago - 3 years 10 months ago #260326 by andypugh
Which version of Glade have you installed? (And which version of LinuxCNC
If you are on LinuxCNC 2.8 then you need the Glade version here: www.linuxcnc.org/dists/buster/base/binar...k2_3.8.6-1_amd64.deb
But it is probably best to get it through the package manager. Make sure that you are getting a package called glade-gtk2.
Last edit: 3 years 10 months ago by andypugh.
3 years 7 months ago #265786 by zz912
I am trying run spindle_load.py for LCNC 2.9 by HansU, but it types:
  File "/usr/lib/python3/dist-packages/gi/overrides/Gtk.py", line 110, in _builder_connect_callback     handler, args = _extract_handler_and_args(obj_or_map, handler_name)   File "/usr/lib/python3/dist-packages/gi/overrides/Gtk.py", line 90, in _extract_handler_and_args     raise AttributeError('Handler %s not found' % handler_name) AttributeError: Handler on_hal_status_interp_run not found glade/spindle_load.py:3: unterminated quoted string 'halcmd -f glade/spindle_load.py' exited with 1
I  use RIP instalation.
3 years 7 months ago #265788 by HansU
The following user(s) said Thank You: zz912
3 years 7 months ago #265794 by zz912
I tried it now, and it works.
Thank you.
Moderators: newbynobi, HansU
Time to create page: 0.305 seconds
