Spindle Load feedback in Gmoccapy
3 years 7 months ago #266305 by HansU
There are several sample configs which are showing how the -H option works.
I suggest you try those and compare them with your configuration.
For example:
configs/sim/gmoccapy/gmoccapy_left_panel.ini   18,1: EMBED_TAB_COMMAND = gladevcp -x {XID} -H v_buttonlist.hal v_buttonlist.glade configs/sim/gmoccapy/gmoccapy_right_panel.ini   14,1: EMBED_TAB_COMMAND = gladevcp -x {XID} -H vcp_box.hal vcp_box.glade configs/sim/gmoccapy/gmoccapy_with_user_tabs.ini   34,1: EMBED_TAB_COMMAND = gladevcp -x {XID} -H vcp_box.hal vcp_box.glade
3 years 7 months ago #266306 by HansU
If that does not lead to success you are welcome to post your configuration.
The following user(s) said Thank You: zz912
3 years 7 months ago #266309 by zz912
I found problem:
This works:
EMBED_TAB_COMMAND = gladevcp -x {XID} -H ./gladevcp.hal ./spindle_load.glade
This NOT works:
EMBED_TAB_COMMAND = gladevcp -x {XID} ./spindle_load.glade -H ./gladevcp.hal
The following user(s) said Thank You: ChironFZ16
3 years 7 months ago #266311 by HansU
Sorry for the complications, I didn't know that the order there is important. But nice that it works now.
3 years 7 months ago - 3 years 7 months ago #266312 by zz912
I'm glad you made this bar in the first place.
Perhaps this could be pointed out in the documentation.
Last edit: 3 years 7 months ago by zz912.
2 years 6 days ago #313268 by besriworld
Hello, I created a panel in Glade. However, when I load it in LinuxCNC, it appears faded and shadowed. What could be wrong?
Moderators: newbynobi, HansU
Time to create page: 0.328 seconds
