Display slightly too big
3 years 3 months ago #275990 by 10K
Replied by 10K on topic Display slightly too big
I changed the numbers to 0,0,1024,768 under "Start of window". I cycled through that option (which worked correctly as expected), and then back to "Start as fullscreen" (which showed the display correctly, as described above). I exited LinuxCNC and restarted. It still exhibits the same behavior where the screen is slightly too big.  So, the size of the windowed screed does not seem to affect the strange behavior.
3 years 3 months ago - 3 years 3 months ago #275991 by besriworld
Replied by besriworld on topic Display slightly too big
I think I have the same problem. The monitor has a resolution 1366x768 . I am working with AXIS gui. But this monitor is only temporary.
Last edit: 3 years 3 months ago by besriworld.
3 years 3 months ago #276207 by zz912
Replied by zz912 on topic Display slightly too big
I have same problem.
3 years 3 months ago #276209 by cmorley
Replied by cmorley on topic Display slightly too big
try a different window manager if you can - might be a bug with the manager.
3 years 3 months ago #276210 by zz912
I dont know how.
3 years 2 months ago #276838 by HansU
Replied by HansU on topic Display slightly too big
I can reproduce this behaviour on XFCE on X11.
Yes you are right. I tested with GNOME under Wayland and it doesn't show this behaviour.
Moderators: newbynobi, HansU
Time to create page: 0.188 seconds
