Gmoccapy & carousel.comp problems after update
2 years 3 weeks ago #311427 by Trav328
I have read that there has been no changes to the carousel.comp , I'm thinking it has to be somewhere else.
When doing the 1 tool change it will do upon startup iocontrol.0.tool-change goes true then back to false and will not go true again.
Here is a video showing that.
youtube.com/shorts/ikY9XmgKaUE?si=r2Xf1ZPs4eCSNlDe
2 years 3 weeks ago #311430 by Aciera
looking in halshow everything related to carousel seems to be functioning fine using my tool change jog buttons, its as if ive lost communication between gmoccapy and carousel , but only after the forst tool selection.
I presume you are not using the gmoccapy tool change dialog so I don't see why gmoccapy would need to play any role in this and indeed looking at the halfile you attached and comparing that to the screen shot of your postgui_halfile it seems that the signals in the postgui_halfile are actually not connected to anything (which I think is correct):
net tool-change iocontrol.0.tool-change => carousel.0.enable net tool-changed iocontrol.0.tool-changed <= carousel.0.ready net tool-number iocontrol.0.tool-prep-number => carousel.0.pocket-number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
The question is why the MDI toolchange does not seem to work after the first change.
Maybe you could test if it works properly if you use a gcode file. If that also fails to work after the first change then it is not likely to be related to gmoccapy at all.
So my suggestions are:
- Test in a sim config on your machine
- Test with your machine config using a gcode file
2 years 3 weeks ago #311440 by Trav328
I just went out to the shop and ran a program , it behaves exactly the same , the offsets and tool number chnage but the physical tool does not , then the program just continues on.
Im not sure what you mean by try in a sim.
I have noticed this since the update aswell , possibly related to something missing or out of place ? , the first time i open linux cnc it starts in some odd configuration,  notice the 5 decimal places and world mode at the bottom,  then I have to close and re open to continue.
2 years 3 weeks ago #311481 by Aciera
Try to run one of the Gmoccapy simulation configs for lathe located in 'configs/sim/gmoccapy/lathe_configs'.
2 years 3 weeks ago #311501 by Trav328
the 2 sims i ran seem to run fine
2 years 3 weeks ago #311510 by Trav328
A full reinstall of debian 12 , linuxcnc 2.9.2 and gmoccapy 3.4.6 has everything working again , must be a bug somewhere in the update.
Moderators: newbynobi, HansU
Time to create page: 0.155 seconds
