LCNC 2.10 - Ask for AUTOMATIC_G43
- HansU
- Thank you received: 217
13 Mar 2025 15:49 #323869
by HansU
This installs LinuxCNC 2.9.4 and change_g43.ngc was added only in master.
Replied by HansU on topic LCNC 2.10 - Ask for AUTOMATIC_G43
I made:
sudo apt install linuxcnc
- zz912
- Thank you received: 98
14 Mar 2025 07:30 #323918
by zz912
Replied by zz912 on topic LCNC 2.10 - Ask for AUTOMATIC_G43
I know 2.9 doesn't have change_g43.ngc.
That's why I searched gmoccapy.ini to find the location of the template configuration files.
Do you think the location of the template configuration files is different for 2.9 and 2.10?
zdenek@cnc:~$ find / -name gmoccapy.ini 2>/dev/null
/home/zdenek/linuxcnc/linuxcnc-master/configs/sim/gmoccapy/gmoccapy.ini
/home/zdenek/linuxcnc/linuxcnc-2.9/configs/sim/gmoccapy/gmoccapy.ini
/usr/share/doc/linuxcnc/examples/sample-configs/sim/gmoccapy/gmoccapy.iniDo you think the location of the template configuration files is different for 2.9 and 2.10?
- HansU
15 Mar 2025 04:49 #323995
by HansU
So I don't get what your problem is..
NoDo you think the location of the template configuration files is different for 2.9 and 2.10?
The following user(s) said Thank You: zz912
- zz912
15 Mar 2025 12:03 #324007
by zz912
I'll try to recap the previous posts. What I want to do can be done in multiple ways.
1)my first original plan.
Create new files in the linuxcnc/src/emc/usr_intf/pncconf folder and then copy them to the new LCNC configuration using pncconf.
I could do this. It is not problem for me.
2)However, @Aciera came up with a better idea.
He doesn't want to create new files in the linuxcnc/src/emc/usr_intf/pncconf folder.
He wants to use the original data from the configs/sim/gmoccapy folder.
The advantage is that there will be no unnecessary duplicate data in the source files.
The problem is that I don't know how to define this path cleanly: configs/sim/gmoccapy
This path is different for RIP installation and different for package installation.
I can define the path for the RIP installation. It is not problem for me.
For package installation I could use the path:
I don't know if this is a clean solution.
I think a clean solution would be to use this variable:
github.com/LinuxCNC/linuxcnc/blob/1c72d4...ipts/linuxcnc.in#L53
But I don't know how.
- HansU
16 Mar 2025 10:44 - 16 Mar 2025 10:47 #324059
by HansU
On a LinuxCNC 2.9.4 installation I find 'change.ngc' in '/usr/share/linuxcnc/ncfiles/remap-subroutines', so I am pretty sure everything in "nc_files/remap-subroutines" is copied there during the installation of LinuxCNC.
So we only need to move 'change_g43.ngc' from "configs/sim/gmoccapy/macros/" to "nc_files/remap-subroutines" and maybe adjust the path in the sample config(s).
Last edit: 16 Mar 2025 10:47 by HansU.
Moderators: newbynobi, HansU
Time to create page: 0.153 seconds
