Change Tool Offsets after editing the Tool Table
1 year 5 months ago #328048 by hermann1976
Current Release: 2.9.4
1 year 5 months ago #328099 by zz912
You can easy change it.
Add this code to gmoccapy.py file to "def on_btn_apply_tool_changes_clicked"
        if "G43" in self.active_gcodes:             self.command.wait_complete()             self.command.mode(linuxcnc.MODE_MDI)             self.command.wait_complete()             self.command.mdi("G43")             self.command.wait_complete()
like this:
1) G43 must be activated
2) after input new value in cell you MUST confirm it for example by key ENTER, then you can click on Apply
3) after click on Apply button you will see right correction value
1 year 5 months ago #328121 by hermann1976
Thanks for your answer.
But Linuxcnc will coming up with an error:
1 year 5 months ago #328124 by zz912
You probably have tabs on that line instead of spaces.
1 year 5 months ago #328125 by zz912
It's a good idea to set this permanently in Geany:
stackoverflow.com/questions/5287849/how-...e-in-geany-on-ubuntu
I tested the code yesterday and found that it's a good idea to go back to MANUAL_MODE:
        if "G43" in self.active_gcodes:             self.command.wait_complete()             self.command.mode(linuxcnc.MODE_MDI)             self.command.wait_complete()             self.command.mdi("G43")             self.command.wait_complete()             self.command.mode(linuxcnc.MODE_MANUAL)             self.command.wait_complete()
1 year 5 months ago #328142 by hermann1976
thank you for your answer,
so the code block is included like your post and i didn't get an error.
The change of the length in Z is working (with apply) but the diameter doesn't change still not.
Moderators: newbynobi, HansU
