LinuxCNC Features - a kind of NGCGUI
12 years 5 days ago #52416 by FernV
Replied by FernV on topic LinuxCNC Features - updated files ?
Hi Nick,
Congratulations for creating a fantastic plug-in that in my opinion will be appreciated by beginners like me and users that do not use it on a regular basis. I think it is promising and has a future.
I was able to download and install it quite easily following the README.md but I wonder if those files are up to date, they seem quite old for a product in it's infancy.
  • Mill.xml has many broken link between *.ini file and their address on disk, same for lathe.xml
  • To execute as stand alone and see the result in LinuxCNC, I have to execute as sudo
  • Only linear array, circular array and n-gon are working, everything else result in errors in Terminal even after updating mill.xml like this when trying to show a Center Rectangle:
    File "./features.py", line 912, in refresh
    f.write(self.to_gcode())
    File "./features.py", line 894, in to_gcode
    g,d = self.refresh_recursive(iter)
    File "./features.py", line 871, in refresh_recursive
    gcode_def += f.get_definitions()
    File "./features.py", line 257, in get_definitions
    s = self.process(self.attr["definitions"])
    File "./features.py", line 324, in process
    s = re.sub(r"(?i)(<eval>(.*?)</eval>)", eval_callback, s)
    File "/usr/lib/python2.7/re.py", line 151, in sub
    return _compile(pattern, flags).sub(repl, string, count)
    File "./features.py", line 287, in eval_callback
    return str( eval(m.group(2), globals(),{"self":self}) )
    File "<string>", line 1, in <module>
    File "./features.py", line 274, in include_once
    return self.include(src)
    File "./features.py", line 265, in include
    f = open(search_path(SUBROUTINES_PATH,src))
    TypeError: coercing to Unicode: need string or buffer, NoneType found
  • There are inconsistencies in the interface, sometimes it is cX, CX or DX, though the order is right in the *.ini file, it is not the same in the interface
  • "Rappid" does not seem a significant word in LinuxCNC but I think I understand the meaning
  • po file is incomplete
I am using Debian Wheezy with LinuxCNC 2.6.3
I guess some work has been done since the last update of the files in gethub repo. Will you update soon ? I do not understand how others can say that it runs perfectly when I can not with supposedly the same files.
Regards
P.S. I can complete the translation in 2-3 days to french if I have a complete po file and will be happy to contribute
12 years 4 days ago #52419 by Nick
Replied by Nick on topic LinuxCNC Features - updated files ?
Hi!
Honestly, I have not tested Features with 2.6.3 yet.
We have tested it only with pre-releases of 2.6.
I'll try to find out what's wrong with 2.6.3.
If you will make po file it will be amazing :)! Features are going to be multilingual :)
12 years 4 days ago #52475 by FernV
Hi Nick,
I have a suggestion, maybe some titles could be changed like :
  • Linear and Circular Array Number and Tool Number have 2 different meanings, the first one means Quantity while the second one is an ID, so Linear and Circular array could be Quantity or Count while Tool could be Ident
  • In Gcode, could Variable be better than Line ?
Sorry, I have a better understanding of CX and DX
Your plug-in is intuitive and pretty well thought
Regards
12 years 3 days ago #52484 by Nick
FernV wrote: Hi Nick,
  • Can you attach a screenshot I do not understand that quite well...
  • What do you want to be instead of line?
    12 years 3 days ago #52515 by FernV
    Hi
    I assigned the wrong translation to Number in one place and it created confusion. "Number" is OK in all cases.
    When I first selected Custom Gcode, I had no idea at all what Line 1-5 were about. It is only when reviewing your video that I understood. However, I think "Variable" could be a better term, I would have understood that it is an object which would need a value.
    Is it supposed to write "features.ngc" in the topmost directory ? Or should it be in either ~/linuxcnc or ~/linuxcnc-features-master ?
    Most errors are the same when linuxcnc is not updated :
    I searched www.google.com/search?q=TypeError%3A+coe...weasel-a&channel=nts
    and I had lot of answers but since I do know python at all I have no idea what all this means
    Regards
    12 years 1 day ago - 12 years 18 hours ago #52605 by FernV
    Replied by FernV on topic LinuxCNC Features - french translation
    I am almost finished with translation to French. Every strings have been translated but there are some I am not sure because I do not understand fully hox CNC works.
    Here are a few screenshots.
    When I have it work, I will be able to correct the rest but if some French speaking people is willing to help, I include the language files. Just edit linuxcnc-features.po with poedit and when you save, it compiles automatically to mo. Re-open LinuxCNC Features to view the modifications.
    To install the language file, unzip the archive file in LinuxCNC-features/locale folder and follow the point 6 of INSTALL in README.md
    File Name: fr_language.tar.gz
    File Size:11 KB
    Regards
    PS - I was only able to test in stand alone mode, plug-in would NOT load language translation. It only includes translation for mill. I was unable to load lathe.xml catalog in stand alone mode, only as plug-in. Until I can have ALL Features show in LinuxCNC simulator, not only arrays and n-gon, I will not do more translation.
    Last edit: 12 years 18 hours ago by FernV. Reason: Add a note
    The following user(s) said Thank You: Nick
    Time to create page: 0.252 seconds
