LinuxCNC Features - a kind of NGCGUI
12 years 22 hours ago #52608 by Nick
Replied by Nick on topic LinuxCNC Features - a kind of NGCGUI
Awesome!
I've added it to latest dev version!
11 years 11 months ago #53079 by cparsons
Replied by cparsons on topic LinuxCNC Features - a kind of NGCGUI
Looks very nice - I have installed this but cannot get it to load, there appears to be a path error?
A lot of the ini files being referenced appear to be in a ../subroutines/mill folder NOT ../subroutines, but I cannot find where this path is set?
I saw a post on the Russian forum about adding the path to the ini file for my mill
<RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINES_PATH = /home/chris/linuxcnc-features-master/subroutines/mill
but this did not work - the error messages still referred to the original path? (/home/chris/linuxcnc-features-master/subroutines)
Where is this path set?
Thank you
Chris
11 years 11 months ago #53081 by Nick
Hmmm Features uses it's own path to get it's own subroutines...
Some errors on startup can appear - some subroutines have moved and we have not clean them up yet, but most of them should work...
How do you start features, as stand-alone application or integrated into axis?
11 years 11 months ago #53082 by cparsons
I have run LinuxCNC and there is nothing different in Axis, so I opened a terminal window and tried standalone and got the attached errors?
I have found where the SUBROUTINES_PATH is set but it looks as if the paths to the ini files are resolved by looking at the mill.xml file in the
subroutines/catalogs folder but cannot understand how this works at the moment!
The install directions do not mention amending the ini file for your machine (mine is called Sieg_SX3.ini) - do I need to add anything to this or
change it?
Chris
11 years 11 months ago #53083 by Nick
Normally you should not add anything. It should just start...
Does any new window appear? Because I usually get those warnings, but features shows up...
PS I have sieg x3 as well, but I have no time to work with it :( and it has it's own controller...
How is sieg in work?
The following user(s) said Thank You: cparsons
11 years 11 months ago #53084 by cparsons
Think I have found one of the problems?
The mill.xml file has a lot of incorrect paths to the ini files, I have corrected these (one ini file was not there at all, I have commented this out?)
The standalone starts up with no errors now, and I can add controls to the top window, but nothing appears in LinuxCNC - just the default 'LinuxCNC' gcode? The bottom window shows a icon with a red cross like a broken image until you select a control when you start which confused me - I thought it had not started properly
I am very new to LinuxCNC (and Python!), I have only just started converting my mill to CNC, if you want to see progress have a look at these videos I posted on DropBox?
www.dropbox.com/sh/74r93l5dieo1h47/AACfA...eOzgB2tQKzH8cPa?dl=0
This is used for a hobby, I make model steam engines :)
Best wishes
Chris
Time to create page: 0.162 seconds
