LinuxCNC Features - a kind of NGCGUI
12 years 4 months ago #47847 by phillc54
Replied by phillc54 on topic LinuxCNC Features - a kind of NGCGUI
I am currently using 2.6.0-pre3-37-gd131cf1.
12 years 4 months ago #47850 by andypugh
Replied by andypugh on topic LinuxCNC Features - a kind of NGCGUI
phillc54 wrote: I am currently using 2.6.0-pre3-37-gd131cf1.
Do the other named parameters exist?
(You can test in the MDI window with (debug, #<_motion_mode>) for example. You need the brackets and braces, and no space before the comma)
12 years 4 months ago #47881 by phillc54
Yes, they appear to exist. ( I tested using your example plus #<_x>, #<_y> & #<_z>)
More version numbers if it helps (or hinders...)
phill@lcnc:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 12.04.4 LTS Release: 12.04 Codename: precise phill@lcnc:~$ uname -a Linux lcnc 3.4.55-rtai-2 #1 SMP PREEMPT Sun Dec 15 23:40:48 MST 2013 i686 i686 i386 GNU/Linux phill@lcnc:~$
12 years 4 months ago #47890 by andypugh
I think we have become confused.
Mariusl said that #<_z> didn't exist, then Phillc54 said that it did.
Both could be true.
12 years 4 months ago #47892 by mariusl
Replied by mariusl on topic LinuxCNC Features - a kind of NGCGUI
The error that comes up when you run it first time and use the OD subroutine is that it does not exist. Once that has happened nothing goes on from there. No update or refresh or nada.
Regards
Marius
www.bluearccnc.com
12 years 4 months ago #47895 by phillc54
I just tried the probe routines, they post to axis ok but are missing the following parameters: #<_global_probe_feed>, #<_global_latch> & #<_global_latch_feed>.
It all seems really random to me, some things post to axis, some don't, some things save, some don't.
Back to the good ol' ngcgui methinks...
Time to create page: 0.371 seconds
