- Thank you received: 124
LinuxCNC Features - a kind of NGCGUI
- FernV
10 years 7 months ago #70985
by FernV
Replied by FernV on topic LinuxCNC Features - a kind of NGCGUI
Hi Otto
My problems with my mill are :
I have to make it usable in order to actually test my new ngc files before releasing them. I do not want to do it only on sim testing. I want to show it running on the preview video.
Another thing I did to help in the development of files is write a "Syntax Highlighting System" that includes Code Folding and Error Detection. I selected Kate from KDE because it supports folding by indentation, it is so easy of use and features rich and also because it ranked best editing app in all review I read. After using it I like it so much that I think I will drop Notepad++. GEdit does NOT support folding.
Screenshots of it in the Windows version
You can easily see where errors are
This is for the ini files used (renamed *.cfg)
You can see that changing colors is very easy, unlike gedit
I submitted the file to KDE for inclusion in katepart but if someone would like to try it first hand I would be happy to post it here
Regards
Fernand
- PC had too much latency Max Jitter was up to 174000, When I removed the PCI-e GC, it went down a bit but max was still 54000. It was right when I set it up but it seems that some apps were causing problems. I ordered a new MB and CPU but I had to replace the CPU except that the problem then was the MB. After rebuilding the PC and a fresh reinstall, the first Latency test Max Jitter was 49000 and it stayed high with Iceweasel only. I reinstalled the first one yesterday and first test showed MJ of 4000 but it have not made an extensive test yet
- Another problem is that I can not have output to control my spindle speed on any pin. Maybe it is only a configuration problem ?
Regards
Fernand
- OttoDidact
- Thank you received: 3
10 years 7 months ago #70986
by OttoDidact
Replied by OttoDidact on topic LinuxCNC Features - a kind of NGCGUI
Ferdinand,
Latency can be a real pain. I usually get an office computer, mainly Dells, from the local university surplus. Fortunately they are cheap since they are old they tend to die after a while in the shop.
On this latest computer a software update two days ago halved it.
I also tried to do Gcode syntax highlighting on Notepad++ it was frustrating and I moved on. I still use it on Windows as it seemed to be the best of the bunch. My new LinxCNC install is on Debian so I'm getting used to Mousepad, I'll see if I can install Kate. I'd really like to be able to do some light programming at the machine like figuring out HAL files and some Python M files. Can you post the file here? I'm sure others will find it useful and help with the bug reporting.
What's your spindle drive setup? I have not attempted to do LinuxCNC controlled variable speed yet, especially since I've had two Minarik DC drives fail on my mill spindle. I made a simple power supply and it's running full speed now, which is OK since I'm mainly doing aluminum with 8mm or less cutters. But I sure have spent a bunch of time reading the forums here and at CNCzone and maybe some new eyes can help you figure it out.
Regards,
Otto
That's enormous! The worst I've ever seen is half that, but It sounds like the new parts might have that in check.Max Jitter was up to 174000
Regards,
Otto
- aer73
10 years 7 months ago #71166
by aer73
Replied by aer73 on topic LinuxCNC Features - a kind of NGCGUI
Hello
Somebody can tell me if is posible get that in Spanish language?
If is posible what are the steps to do?
Many thanks in advance.
Kindly regards.
Kindly regards.
- FernV
10 years 7 months ago #71173
by FernV
Locale files have not been included in this version since it is under development and updated/new files are sure to have many changes in displayed strings. Not that the application will have many changes but ALL the ini files will. Some files will be deleted. I think it would be a loss of time at this moment, developing better ngc files is at top in the priority list and I admit I still have a lot to learn about machining.
If you really need spanish language, command is ./features.py -t . A file will be created and you edit using poedit. If you still want to do it at this stage, I can give you more info.
Regards
Fern
Regards
Fern
- aer73
10 years 7 months ago #71176
by aer73
@Fernv.
Many thanks for your words.Now i have a better idea.
Otherwise i want to be familiar with changes and practice over this version, no problem.
I try that you say to change language and if you can give me some more info, please.
Many thanks again for your great work and help.
Kindly regards.
Kindly regards.
- FernV
10 years 7 months ago - 10 years 7 months ago #71365
by FernV
Hello
Next time, please post your question to this forum for everybody to see it and my answer.
For your translation, create a subdir : locale/es/LC_MESSAGES
Move your linuxcnc-features.mo in it
In a terminal type
cd /usr/share/locale/es/LC_MESSAGES
sudo ln /<full path to features sourse>/locale/es/LC_MESSAGES/linuxcnc-features.mo -s
That is all
Fernand
In a terminal type
That is all
Fernand
Last edit: 10 years 7 months ago by FernV.
Time to create page: 0.288 seconds
