- Thank you received: 124
LinuxCNC Features - a kind of NGCGUI
- FernV
11 years 4 days ago #64372
by FernV
Line 290 of mz_engrave.ini under '[PARAM_YOFF]' should be 'header = h3' insead of 'h4'
That will correct everything
Fern
Replied by FernV on topic LinuxCNC Features - a kind of NGCGUI
fixer wrote: ... there is a wrong header value in mz_engrave for PARAM_YOFF. The error only shows up when showing sub groups in master tree.
Fern
- FernV
11 years 3 days ago - 11 years 3 days ago #64426
by FernV
Hi Mit
There is another correction to do in fv_entry-angle,ngc :
replace line 17 that says
with
line 42 tries to divide by tool radius, it was OK when adding a small number but not multiplying 0 * 0.501
It should also be corrected in fv_entry-arc.ngc (line 21) though there is no such division
Regards
Fern
o<comp00> if [#<opt> EQ 2] (no compensation)
with
o<comp00> if [[#<opt> EQ 2] OR [#5410 EQ 0]] (no compensation)
Regards
Fern
Last edit: 11 years 3 days ago by FernV.
- FernV
11 years 1 day ago - 10 years 11 months ago #64531
by FernV
Hi Mit
I am currently finallizing 'polyline' and some parts are very difficult to implement. Hopefully in a couple of weeks it is ready to release. Not sure I will have time to review the way it creates pockets but it is on my todo list
Regards
Fern
EDITED...
Finally, I modified TopFeatures and renamed to History and it will be possible to have 2 blocks of buttons or only one. When you select a number of most popular features, the left block will show them over time since the last time you deleted catalog/mill/top.lst. If none are selected, you will have only buttons sorted with last feature used at the left.
ALL configuration options will be done in the preference dialog (not in feature.py anymore) and the preference file will not be updated with new release, meaning you will not have to do it again.
I also checked if I could debug engrave-feature but I found that TABS and SPACES were both used for indentation. I tried to replace all TABS with 4 spaces but it messes up the indentations and it would not run anymore. I finally downloaded engrave-lines and found it only uses SPACES and I was able to reset the indentation OK. I will be able to debug and hopefully have it ready for next release.
Fern
Top Features is allready history. It changes with time bringing the most used the leftmost. It can be resetted by deleting catalog/mill/top.lst I think the problem lies in the fact that icons are not clear enough, I mean we do not have enough icons or the wrong one is selected, I admit that I did overlook that. However what is your idea on this ? Do you think of having the last one used placed on far left or ... ?fixer wrote: -I would replace top features with features history.
Regards
Fern
EDITED...
Fern
Last edit: 10 years 11 months ago by FernV.
- fixer
- Thank you received: 27
10 years 11 months ago #64771
by fixer
Replied by fixer on topic LinuxCNC Features - a kind of NGCGUI
what do you need to debug on engrave-feature? Have you found any more bugs? sorry for the indetation problem, it doesnt show in my editor.
do you have the latest version? (check a few posts above).
- FernV
10 years 11 months ago #64775
by FernV
I am going to fix the mirror issue. The indentation problem is caused by your editor that insists to use tabs instead of using a number of spaces. I do not know if in preferences you have this option but gedit has. Python works best with spaces.
Fern
fixer wrote: what do you need to debug on engrave-feature?(check a few posts above).
Fern
- fixer
10 years 10 months ago #66440
by fixer
Hi Fernand,
Another idea:
I would like to have "save as default template" called just before app is closed. So the current work gets automatically saved, and reopened on restart. How can I achieve this? Should be simple, calling actionSaveTemplate in exit handler, but I don't know the proper syntax....
Another idea:
Time to create page: 0.477 seconds
