NativeCam raspberry Pi 4
9 years 4 months ago - 9 years 4 months ago #94381 by gmouer
Well !!!! Just for kicks I clicked my old desktop shortcut which I believed would no longer work because of the new directory structures and such for NativeCam AND............ a window popped up telling me of the new directory structure AND asking me if I wanted to update. I clicked yes and magic happened, Linuxcnc launched with embedded nativecam. Lots of new icons in nativecam from the latest release.
It looks like I am good to go !!!
VERY nice work Fern !! Documenting some of how the new deb system will work and what to expect would save some unnecessary questions like the ones I posted.
Thanks much,
George
Last edit: 9 years 4 months ago by gmouer.
9 years 4 months ago #94389 by FernV
gmouer wrote: ...What is lacking is any info on where NativeCam now resides
Just for your info it is : /usr/share/linuxcnc/aux_gladevcp/NativeCAM
but like all other applications on your system, you should never access it directly
gmouer wrote: ...and how to launch it !
In any directory just type 'ncam' or 'nativecam' without extension, just like you do with 'gedit'
gmouer wrote: ...I have not deleted my old NativeCam directory just yet because I have not located the new installation ! Also, I am guessing that my old tooltable and configs were not ported into the new install and I will need to redo those along with my desktop shortcuts.
Your tool table ang configs are always in the directory where your inifile is
gmouer wrote: ...Also, how to launch it imbedded with the latest installations
Nothing has changed from non_deb version in the setting up of new config, type 'ncam -h' for info
Fern
9 years 4 months ago #94458 by newbynobi
Hallo Fern,
I just tried to install NativeCAM with your script, but the package nativecam can not be found.
gmoccapy@machinekit:~$ curl -s https://packagecloud.io/install/repositories/FernV/NativeCAM/script.deb.sh | sudo bash Detected operating system as debian/jessie. Checking for curl... Detected curl... Running apt-get update... done. Installing debian-archive-keyring which is needed for installing apt-transport-https on many Debian systems. Installing apt-transport-https... done. Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done. Importing packagecloud gpg key... done. Running apt-get update... done. The repository is setup! You can now install packages. gmoccapy@machinekit:~$ sudo apt-get install nativecam Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig E: Paket nativecam kann nicht gefunden werden.
Is that, because I am running Jessie?
Norbert
9 years 4 months ago - 9 years 4 months ago #94461 by eFalegname
Hi Fern! I've got the same message in ubuntu 10.04. Maybe because my old ubuntu is not supported at all.Is it?
Last edit: 9 years 4 months ago by eFalegname.
9 years 4 months ago #94463 by FernV
newbynobi wrote: Hallo Fern,
Hi Norbert,
The package is registered as a wheezy though it is the same for all.
I will make it available for at least Jessie or better 'all' if possible on packagecloud.io
It will be done in 5 hours from now.
Fern
9 years 4 months ago #94471 by newbynobi
Hallo Fern,
I just changed the jessie part to wheezy in synaptic :)
I was able to install and use it within gmoccapy.
In your docu you write the -t parameter will only work with axis, but I tried with gmoccapy that parameter and it seem to work.
After the first part in sim config i found, that the program won't run with your sample gmoccapy mill mm config, as you missed to include sim_spindle.hal, so you will never get a spindle_on_speed signal. Also the macros has been disabled, they can work besides NativeCAM, without giving any trouble. I also added the gmoccapy_postgui.hal file, as that one does link the spindle at speed LED, the feedback bar and it does enable also the tool change dialog.
Please find attached my config folder. I would thank if you do change the sim config to include also the disabled gmoccapy features.
Norbert
Time to create page: 0.079 seconds
