- Thank you received: 124
Try now, it is available for Wheezy, Jessie, Lucid and Trusty.eFalegname wrote: Hi Fern! I've got the same message in ubuntu 10.04. Maybe because my old ubuntu is not supported at all.Is it?
Thanks for the tipnewbynobi wrote: ...I just changed the jessie part to wheezy in synaptic
I was able to install and use it within gmoccapy.
The -t or --tab has effect only with axisnewbynobi wrote: In your docu you write the -t parameter will only work with axis, but I tried with gmoccapy that parameter and it seem to work.
The reason is avoiding confusion by showing only features that are part of NativeCAMnewbynobi wrote: After the first part in sim config i found, that the program won't run with your sample gmoccapy mill mm config, as you missed to include sim_spindle.hal, so you will never get a spindle_on_speed signal. Also the macros has been disabled, they can work besides NativeCAM, without giving any trouble. I also added the gmoccapy_postgui.hal file, as that one does link the spindle at speed LED, the feedback bar and it does enable also the tool change dialog.
Please find attached my config folder. I would thank if you do change the sim config to include also the disabled gmoccapy features.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...curl: (7) Failed to connect to packagecloud.io port 443: Network is unreachable
Try to open this page :joey81 wrote: ...Failed to connect to packagecloud.io port 443: Network is unreachable
