NativeCam raspberry Pi 4
9 years 3 months ago #95354 by racedirector
Hi Fern
The biggest issue I see is the forced truetype_tracer dependency, Mint 18 does not have it available. So to get around that I downloaded a 32 bit deb of tt-t and installed that then tried nacm. Didn't work as ncam said it still needed tt-t. So I then removed tt-t again and installed it from source. That didn't work either.
In the end I downloaded the Ubuntu Trusty deb from you and forced the install with dpkg --force-all -i (installs without missing dependencies) and it worked. I then reinstalled tt-t and so far all is well. I have followed the usual directions to get ncam running embedded in gmoccapy. As as side note I probably will never use Truetype tracing as I use Vectric Aspire and Fusion 360 for my CAM work so the requirement to install it alongside ncam, for me, was un unnecessary distraction.
Now all I have to do is work out how to get ncam to start up with a blank screen, my copy of gmoccapy complains the it can't be in one of the modes until I get it out of estop, either MDI or AUTO. Can't remember that bit as I have pulled the computer apart to replace the case and power supply.
Hope that helps in some way.
Cheers
The following user(s) said Thank You: FernV
9 years 3 months ago #95360 by FernV
racedirector wrote: ..all I have to do is work out how to get ncam to start up with a blank screen
You can not. For every project, you have to define some parameters and this is what the default template does. Set the parameters at the values you need then save it. You can not use a circle only because it will result in an error that some parameters are not defined.
If you try to save a blank template, it will simply erase the it but next time it will copy the default template back. A template is a quick way to start a project.
Fern
9 years 3 months ago #95374 by lagore
I am trying to get ncam to run in a tab but don't quite understand how to, I have put ncam -t in place of ncam but it still does not display in a tab and mess' my screen real estate!
9 years 3 months ago #95375 by FernV
lagore wrote: ...I have put ncam -t in place of ncam but it still does not display in a tab...
You alson need the inifile parameter like :
$ ncam -i inifile -t -c mill
Fern
The following user(s) said Thank You: vmihalca
9 years 3 months ago #95376 by FernV
Using
will setup your inifile to use ncam embeded
Use -t only once
Fern
P.S. This thread should be reserved for installation questions only
9 years 3 months ago #95397 by rene-dev
Im trying to get this to work with sim/axis_mm.ini from linuxcnc master.
I ran /home/emc/dev/NativeCAM/ncam.py -i axis_mm.ini to change the ini file.
when starting, this happens:
emc@emc:~/linuxcnc/configs/axis$ linuxcnc axis_mm.ini LINUXCNC - 2.8.0~pre1 Machine configuration directory is '/home/emc/linuxcnc/configs/axis' Machine configuration file is 'axis_mm.ini' Starting LinuxCNC... Found file(lib): /home/emc/dev/linuxcnc/lib/hallib/core_sim.hal Note: Using POSIX realtime sched_setaffinity: Invalid argument Found file(lib): /home/emc/dev/linuxcnc/lib/hallib/sim_spindle_encoder.hal Found file(lib): /home/emc/dev/linuxcnc/lib/hallib/axis_manualtoolchange.hal Found file(lib): /home/emc/dev/linuxcnc/lib/hallib/simulated_home.hal note: MAXV max: 53.340 units/sec 3200.400 units/min note: LJOG max: 53.340 units/sec 3200.400 units/min note: LJOG default: 30.480 units/sec 1828.800 units/min note: jog_order='XYZ' note: jog_invert=set([]) (gladevcp:11321): libglade-WARNING **: Expected <glade-interface>. Got <interface>. (gladevcp:11321): libglade-WARNING **: did not finish in PARSER_FINISH state **** GLADE VCP ERROR: With xml file: /home/emc/dev/NativeCAM/ncam.ui : could not create GladeXML object <commandline>:0: gladevcp exited without becoming ready Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x 50331808 -U --catalog=mill /home/emc/dev/NativeCAM/ncam.ui" exited with error: 1 Shutting down and cleaning up LinuxCNC... task: 1216 cycles, min=0.000013, max=0.005653, avg=0.001100, 0 latency excursions (> 10x expected cycle time of 0.001000s) Note: Using POSIX realtime LinuxCNC terminated with an error. You can find more information in the log: /home/emc/linuxcnc_debug.txt and /home/emc/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
Time to create page: 0.087 seconds
