NativeCam raspberry Pi 4
9 years 3 months ago #95443 by SteveT
Thanks for your help works now, just need to sort the tool list as that causing it to crash. :-)
9 years 3 months ago #96043 by BigDo
Hi Fern! I've got the same message on a fresh installed ubuntu 12.04.
cnc@cnc:/$ curl -s https://packagecloud.io/install/repositories/FernV/NativeCAM/script.deb.sh | sudo bash [sudo] password for cnc: Detected operating system as Ubuntu/precise. Checking for curl... Detected curl... Running apt-get update... done. Installing apt-transport-https... done. Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done. Importing packagecloud gpg key... done. Running apt-get update... done. The repository is setup! You can now install packages. cnc@cnc:/$ sudo apt-get install nativecamPaketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut Statusinformationen werden eingelesen... Fertig E: Paket nativecam kann nicht gefunden werden cnc@cnc:/$
package nativecam can not be found
how do i fix that?
Niko
9 years 3 months ago #96044 by FernV
BigDo wrote: ...
...package nativecam can not be found
Retry, I just uploaded for Ubuntu/precise
Fern
9 years 3 months ago #96047 by BigDo
ok it works :) thank you very much
Niko
9 years 3 months ago #96211 by verticalperformance
Would you be able to create a deb package for ubuntu/xenial?
9 years 3 months ago #96214 by FernV
verticalperformance wrote: Would you be able to create a deb package for ubuntu/xenial?
Done
Fern
The following user(s) said Thank You: verticalperformance
Time to create page: 0.169 seconds
