NativeCam raspberry Pi 4
8 years 11 months ago #102460 by Geshka
Forgot to mention - I have fresh Debian install and applied nativecam with DEB package.
8 years 11 months ago #102466 by FernV
Your ini file is OK
Try this : delete '/home/gyakubov/Desktop/my-mill/ncam'
Then restart lcnc
Also run ncam standalone and show me the terminal screen result.
Fern
8 years 11 months ago #102469 by FernV
Can you also check if 'python-lxml v2.3.2' or better and 'truetype-tracer v 4.1-4' or better are installed on your pc
Fern
8 years 11 months ago #102513 by Geshka
Python lxml version is
Python 2.7.3 (default, Mar 14 2014, 11:57:14)
[GCC 4.7.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from lxml import etree
>>> etree.LXML_VERSION
(2, 3, 2, 0)
Don't know how to get version of truetype-tracer :(
below is output of ncam from terminal.
gyakubov@LinuxCNC:~/linuxcnc/configs/my-mill$ ncam -i my-mill.ini
NativeCAM info:
inifile = /home/gyakubov/linuxcnc/configs/my-mill/my-mill.ini
NCAM_DIR = /home/gyakubov/linuxcnc/configs/my-mill/ncam
SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM
program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
Created 9 files in /home/gyakubov/linuxcnc/configs/my-mill/ncam/catalogs
Updated 1 files in /home/gyakubov/linuxcnc/configs/my-mill/ncam/my-stuff
[RS274NGC]SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities
Real paths:
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/mill
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities
Using default mill/menu.xml, no mill/menu-custom.xml found
/usr/bin/ncam:2644: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion `gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
Previous work not saved as current work
^CTraceback (most recent call last):
File "/usr/bin/ncam", line 4621, in get_col_icon
def get_col_icon(self, column, cell, model, itr) :
Thanks for your help, Fern
8 years 11 months ago #102521 by FernV
Geshka wrote: ...Don't know how to get version of truetype-tracer
Open Synaptic and search for 'truetype-tracer'. If installed, you will see the version number.
Without 'truetype-tracer', you will not be able to do engraving of TT Fonts.
...below is output of ncam from terminal.
Is this all ? It should give more details about the problem. I do not know if an icon file is missing or the' Preferences' was not read or what ...
Does NativeCAM run well in stand alone mode ? Or does it print lots of message like this one in the terminal ? You should recognize info from error messages.
What is the version installed ? It shows in 'About' dialog or you can find it in Synaptic searching 'nativecam'. Latest published version is 0.1.14b, update if you have an older version.
Fern
8 years 11 months ago #102526 by Geshka
Yes, it runs just fine. Generated G-code passed to the LCNC and refreshes.
I think I can live with that... and I probably like it better. Lat's not waste our time. Thanks for you help and great utility.
Time to create page: 0.133 seconds
