>> What is your Linux distribution ?
Debian GNU/Linux 7, aka wheezy, fully uptodate as of last night. libc6 says its 686 version, aka 32 bit. LCNC didn't work well on 64 bit machines due to the latency created by the much bigger context switch on 64 bit machines. Software step generation with good timing is not possible on 64 bitters. So 64 bit installs can only run at about 1khz servo loops with the stepper driving offloaded to a smart card, like a Mesa 5i25 or a 7i90 and their friends.
I've now nuked it all and installed the deb. Running standalone I still do not have the backplot I see on the left in the you-tube videos. There are some squawks from gladevcp about the camera, and I found that the deb install had somehow nuked the camview.py file in the linuxcnc/config/machinename directory. I had a backup copy, so I restored it, so that is working, mostly. With the lights limited to one 4' led over the lathe about 12 feet away, the camera fps is about 8 and I can expand the axis until the camera output is being scaled up about 30% both ways.
But turn on the overhead lights and and led gooseneck on the side of the mill, the increased fps seems to be too much, and the whole tab turns white because something died, and the only way to resume is to re-start lcnc.
Not your problem either. When it dies, qv4l2 still works for whatever that is worth
More than you wanted to know I suspect.
Its a 640x480 camera. Endoscopy style. El-cheepo at $21 USD. Poor fixed focus, but it lets me get to within a couple thou. Mount needs help, I'm have trouble maintaining its parallax. Not your problem of course.
Not your problem, but camview.py, has an autosize adjust stanza in it that is awful flaky, and the gui buttons under the image need to grow a save button so we can set it and forget it, and it will come back up with those settings as its new defaults the next time its ran. Possibly repurpose the existing debug button since I don't actually see it doing anything.
My own personal python knowledge is not up to that task however.
That also worked well enough to translate the db25 pattern that another user was questioning, and the resultant gcode, fed to linuxcnc on my mill has 2 problems, the left half and the right half look as it the tool rad comp was mirrored, and they are offset vertically as if the z values were also inverted by the mirroring.
Cheers and thank you FernV, Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <
geneslinuxbox.net:6309/gene
