NativeCam raspberry Pi 4
8 years 11 months ago #102529 by FernV
If you are having this problem, someone else might have it too. So help me solve this by answering ALL my questions.
Fern
  • Weiler810T
  • New Member
  • New Member
8 years 10 months ago #102581 by Weiler810T
Replied by Weiler810T on topic Use NativeCAM as a deb package now
Hallo
What's that, Bug or Feature? ;)
task: main loop took 0.013716 seconds
Xlib.protocol.request.QueryExtension
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py:2644: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion `gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
Linuxcnc 2.7.11 Config:
**** GMOCCAPY INFO : postgui halfile = gmoccapy_postgui.hal ****:
gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py
/usr/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
**** probe_screen GETINIINFO ****
Preference file path: /home/chiron/linuxcnc/configs/sim.gmoccapy/gmoccapy_4_axis.pref
NativeCAM info:
inifile = /home/chiron/linuxcnc/configs/sim.gmoccapy/gmoccapy_4_axis.ini
NCAM_DIR = /home/chiron/linuxcnc/configs/sim.gmoccapy/ncam
SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM
program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
[RS274NGC]SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities:ncam/lib/mill:ncam/lib/utilities:macros
Real paths:
/home/chiron/linuxcnc/configs/sim.gmoccapy/ncam/my-stuff
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/mill
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities
/home/chiron/linuxcnc/configs/sim.gmoccapy/macros
Benutze default mill/menu.xml, kein mill/menu-custom.xml gefunden
Voheriger Zustand nicht als aktuell abgespeichert
task: main loop took 0.011793 seconds
task: main loop took 0.011890 seconds
task: main loop took 0.017384 seconds
/usr/lib/pymodules/python2.7/gmoccapy/notification.py:168: GtkWarning: Invalid icon size 48
Current status NativeCam:
8 years 10 months ago #102599 by FernV
Since you do not mention what worries you, I will just comment what I see
Weiler810T wrote: What's that, Bug or Feature?
This is a pygtk warning of a bug that affect keyboard accelerators. In File menu, you do not see the accelerators but you can still use what I implemented for File->Open with <ctrl>O, File->Save with <ctrl>S and File->New with <ctrl>N
I had no other way to work around this pygtk bug
Edit SUBROUTINE_PATH in your ini. Replace it with
ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities:macros
It was doubled probably because NCam was executed twice stand alone on this ini
Everything else looks OK
Regards
Fern
8 years 10 months ago #103246 by Gene1934
Your messages are strange, have you used the deb package or you cloned from GitHub ?
Cloning is NOT supported and if it is what you have done, delete everything related to NativeCAM and install with the script found here :
forum.linuxcnc.org/40-subroutines-and-ng...as-a-deb-package-now
that script is the one that squawked. And I don't have any idea what message I am replying to. It did install your site to /etc/apt/sources.list.d before it died.
Cheers, Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
8 years 10 months ago #103248 by Gene1934
If cloning doesn't work. and the zip git makes isn't good, how do I install it correctly?
8 years 10 months ago #103271 by FernV
Gene1934 wrote: If cloning doesn't work. and the zip git makes isn't good, how do I install it correctly?
What is your Linux distribution ?
Fern
Time to create page: 0.246 seconds
