NativeCam raspberry Pi 4
8 years 11 months ago #102402 by Geshka
Hello Fern.
I installed LinuxCNC and nativeCAM as you recommended at the beginning.
Now I have standalone nativeCAM working , but when j I am trying to start LinuxCNC with embedded ncam I've got empty ncam tab and following test - can you please, suggest how to fix it
gyakubov@LinuxCNC:~$ linuxcnc ~/Desktop/my-mill/my-mill.ini
LINUXCNC - 2.7.0
Machine configuration directory is '/home/gyakubov/Desktop/my-mill'
Machine configuration file is 'my-mill.ini'
Starting LinuxCNC...
Found file(REL): ./my-mill.hal
Found file(REL): ./custom.hal
(gladevcp:7366): libglade-WARNING **: Expected <glade-interface>. Got <interface>.
(gladevcp:7366): libglade-WARNING **: did not finish in PARSER_FINISH state
**** GLADE VCP ERROR: With xml file: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui : could not create GladeXML object
8 years 11 months ago #102403 by FernV
If you use many tabs, NativeCAM has almost certainly replaced one of your command.
Go through this short thread and you will find your solution. If not let me know.
Regards
Fern
8 years 11 months ago #102411 by Geshka
Hi Fern.
Somebody indeed, asked similar question, but I did not found related answer, sorry again if I missed that - I did searched trough several times.
P.S. I am not using any tabs - it is fresh install of Debian/LinuxCNC
Appreciate your help.
8 years 11 months ago - 8 years 11 months ago #102421 by FernV
Post here your inifile and the output of the terminal window.
Have you used the deb package ?
The old method will not work and is not supported anymore, have you used it before ?
Fern
Last edit: 8 years 11 months ago by FernV.
8 years 11 months ago #102435 by FernV
8 years 11 months ago - 8 years 11 months ago #102453 by Geshka
Fern.
Here is startup sequence of the LinuxCNC
gyakubov@LinuxCNC:~/Desktop/my-mill$ linuxcnc my-mill.ini
LINUXCNC - 2.7.0
(gladevcp:5772): libglade-WARNING **: Expected <glade-interface>. Got <interface>.
(gladevcp:5772): libglade-WARNING **: did not finish in PARSER_FINISH state
I also attached ini file.
Thanks a lot
Last edit: 8 years 11 months ago by Geshka.
Time to create page: 0.293 seconds
