NativeCam raspberry Pi 4
7 years 9 months ago #123467 by eFalegname
Hi Fern, could you make me happy with the NativeCam installer for manjaro?
Thanks mate!
7 years 9 months ago #123493 by FernV
eFalegname wrote: ...NativeCam installer for manjaro?
Manjaro is not supported by packagecloud
Follow the instruction in the setup script :
"For example, to force Ubuntu Trusty: os=ubuntu dist=trusty ./script.sh"
I have not tried it myself.
Fern
7 years 3 months ago #140761 by Dinuka_Shehan
Thank you
7 years 3 months ago #140810 by pl7i92
with so many different screens now the featheres cand keep up
if there are not in master integreded and overtuned on new releases
7 years 1 month ago #144700 by Dimitrios
Fern, first of all, many, many thanks for your great effort. Hope not to bother you with noob questions but:
Being fairly ignorant in Linux, for some years i am using LinuxCNC with good results. yesterday I downloaded and installed version 2.7.14, and, for the first time, tried to install NativeCAM, following the procedures on the first page of this thread. all I get is:
'Detected operating system as debian/wheezy.
Checking for curl...
Installing curl...
Reading package lists...
Building dependency tree...
Reading state information...
Package curl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'curl' has no installation candidate
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...ncam_debsetup.txt: line 115: curl: command not found
Unable to run:
curl packagecloud.io/install/repositories/Fer...wheezy&source=script
Double check your curl installation and try again.
I am lost. Synaptic ignore any reference to curl itself, only shows libcurl. i downloaded the curl package, but can't manage to synaptic use it. What I am missing here?
I really appreciate some guidance.
BR
Dimitrios
7 years 1 month ago #144720 by Gene1934
I've had similar. Go ahead and install libcurl, ISTR it works somehow
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
The following user(s) said Thank You: Dimitrios
Time to create page: 0.412 seconds
