NativeCam raspberry Pi 4
7 years 1 month ago #144721 by Dimitrios
Thanks Gene1934! I'll try it and report back.
Regards,
Dimitrios
7 years 1 month ago #144722 by Dimitrios
Well, sinaptic informs me that I have libcurl3-gnutls installed, version 7.26.0-1+wheezy25+deb7u1 which is the latest version.
what now? My ignorance in Linux is troubling me. Do I have to somehow force a new install, using apt-get?
You can point me to some docs, do not want to be a lazy guy!
thanks again, and regards.
Dimitrios
7 years 1 month ago #144727 by Gene1934
Maybe some else, even Fern can help. wget does essentially the same thing but probably needs different cli options. So the scripts that use curl might be editable to use wget.
I think I read someplace quite a while back that curl was using an out of date security library, Its dirt I haven't kicked around much, and the oldtimers memory fades too fast, it will be 85 years old next month. Sorry I can't be more specific.
Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
The following user(s) said Thank You: Dimitrios
7 years 1 month ago #144728 by Dimitrios
Thank you, Gene!
I am searching around, and, if I find a solution, i will post it here.
My mom is 84, and still work as a translator and consultant for language and literature works. She has a PhD in that area.
You are perfectly fine, believe me. Still go a long stretch!
Best regards
Dimitrios
7 years 1 month ago #144740 by okiejim
That curl error was exactly what was happening to me with unbutu lucid. I finally gave up and got the latest debian 9 live dvd and was able to load up NativeCam. I really love NativeCam and will continue to us it as my new go to for CAM.
7 years 1 month ago #144743 by BigDo
try
sudo apt-get install curl
Time to create page: 0.095 seconds
