NativeCam raspberry Pi 4
6 years 1 month ago #182659 by blue0cean
my Values in tool-change.cfg
PARAM_SURF_SPEED]
name = _("Surface speed")
header = h2
type = int
minimum_value = 20
tool_tip = _("Constant spindle speed")
value = 125
grayed = 0
6 years 1 month ago #184318 by Thorhian
Hello!
I am currently trying to install NativeCAM at the moment, but the install script doesn't seem to be working. I then realized that I am on a Raspberry Pi 4, so I am not using an x86-64 arch. I figured that is why the script doesn't install anything when it is finished (with no errors). Is there a way to compile on the RPi and then install?
5 years 6 months ago #206641 by itanc
Hi Fern,
I love NativeCAM and thanks for the work you have put into it. i cant however get it to install. i have a fresh wheezy install and ncam_debsetup.txt on my desktop. when i run sudo bash ncam-debsetip.txt i get the following
tanc@debian5:~/Desktop$ sudo bash ncam_debsetup.txt
[sudo] password for tanc:
Detected operating system as debian/wheezy.
Checking for curl...
Installing curl...
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...ncam_debsetup.txt: line 115: curl: command not found
Unable to run:
curl packagecloud.io/install/repositories/Fer...wheezy&source=script
Double check your curl installation and try again.
tanc@debian5:~/Desktop$ ncam -h
bash: ncam: command not found
any insight?
cheers
tanc
5 years 6 months ago #206655 by tommylight
5 years 6 months ago #206698 by itanc
cheers for the reply tommy,
tried that and got this...
tanc@debian5:~$ sudo apt-get install curl
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package curl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'curl' has no installation candidate
tanc@debian5:~$
thanks again
5 years 6 months ago #206706 by tommylight
Check the menu for "synaptics package manager" or "software sources", open it an click on "enable partner repositories" and "enable source code" or similar, then do
sudo apt-get update
then try again the above line.
Time to create page: 0.124 seconds
