Native CAM - How To Install?
6 years 3 months ago #175569 by Barry
Replied by Barry on topic Native CAM - How To Install?
Bruno, I hope someone will answer your question because I ran into the exact same problem when transferring all of my Wheezy CNC files to a new computer with a fresh installation of Wheezy this past week. I worked on it for countless hours and could not figure out how to install python-lxml. Cloning it from Get-hub is not a problem...just open a terminal and type
git clone github.com/lxml/lxml.git lxml
but then I did not have "pip" to be able to install it. So then I worked on trying to figure out how to install "pip" to be able to run....... sudo pip install lxml.
I did a lot more things and got close but could never get it to fully work. So I gave up and downloaded an iso of Debian 9.0 Stretch to a DVD and installed Stretch. Everything went very smoothly after that and I was able to quickly embed NCAM into the Linuxcnc Axis program, and my CNC was up and running again. I actually like Stretch better than Wheezy.
Note: Once you solve the python-lxml issue, the next issue is figuring out how to install gladevcp if you plan to embed NCAM into Linuxcnc Axis.
If you choose to move to Debian 9 - Stretch and want the installation directions that I documented to repeat the process if necessary, just let me know and I'll post them.
Good luck,
Barry
6 years 3 months ago #175606 by bruno2626
Thank you for your response Barry.
I managed to install python-lxml with pip.
Indeed, now I have a gladevcp error: could not create GladeXML object.
glade-gtk2 was already installed...
So, I'll take your advice about Debian 9.0 Stretch.
Thanks.
Bruno
6 years 3 months ago #175668 by bruno2626
I set up Debian 9.0 Stretch found here (i386 r13):
www.linuxcnc.org/testing-stretch-rtpreempt/
I have the same error with gladevcp.
This is the 4th pc where I install nativecam, the other times were easier!
6 years 3 months ago #175721 by bruno2626
I finally made it.
I had Debian 9 installed with no network. That's a bad idea.
Thanks.
Bruno
6 years 1 month ago #184006 by benbenben
bruno2626 wrote: Thank you for your response Barry.
Thanks.
Bruno
hi bruno,
how do i go about to install phyton lxml with pip. dont have pip as well
trying to import dxf into inkscape and it throws me that error, since i use wheezy
6 years 1 month ago #184174 by bruno2626
Hi benbenben,
I'm sorry, I don't think I'm the best person to answer you. I don't know how I did it at all!
Time to create page: 0.216 seconds
