Native CAM - How To Install?
7 years 5 months ago #135508 by BigJohnT
Did you update the Wheezy sources file since it hit EOL anything to do with apt install broke until you point to the archives.
forum.linuxcnc.org/29-forum-announcement...-repositories#135506
JT
7 years 5 months ago - 7 years 5 months ago #135543 by MJPfin
Replied by MJPfin on topic Native CAM - How To Install?
Done that already, it just wont install nativecam no matter what. Starting to get more than frustrating.
cnc@debian:~/Downloads$ sudo bash ncam_debsetup.txt
[sudo] password for cnc:
Detected operating system as debian/wheezy.
Checking for curl...
Detected curl...
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done.
Importing packagecloud gpg key... done.
The repository is setup! Installing NativeCAM... done.
cnc@debian:~/Downloads$ ncam
bash: ncam: command not found
WHAT now? it says installed but not a single instruction posted works?
Last edit: 7 years 5 months ago by MJPfin.
7 years 4 months ago #135585 by andypugh
Have you found the ncam executable? You might need an explicit path to it.
Then, even when you find it, it probably needs to be started as ./ncam
7 years 4 months ago #135595 by BigJohnT
If it gets installed in /home/user/.local/bin Debian may not be able to find it. I know that Debian 9 does not include the path to .local/bin and you have to put a .xrcsession file in the home directory to fix that. See item 3 here
jethornton.github.io/7i96/install.html
JT
7 years 4 months ago #135610 by MJPfin
Cant find it or even the nativecam folder anywhere. Need to figure this out later as now I'm out of time. I'll get to run my parts at the university machine.
I'll dig around more as I have catch up the time lost with current linux setup fiasco.
7 years 4 months ago #136063 by MJPfin
Not working, nothing gets downloaded for some reason. Week past and no change. Any step by step guide from start to finish?
Manual download and install? Complete working disk image, something.
I am done with trying. When nothing works.
Gone from good and working to complete useless after all changes and updates. Cnc works every single time, ncam is no where to be found.
It just don't exists anywhere. And it's not my network I can download anything I choose but nativecam.
Time to create page: 0.188 seconds
