Native CAM - How To Install?
- MJPfin
06 Jun 2019 17:21 - 06 Jun 2019 17:23 #136073
by MJPfin
Replied by MJPfin on topic Native CAM - How To Install?
Clean install other machine same deal, but now curl installed automatically
Where should the ncam be located? /home/user/.local/bin i dont even find that folder. just home/cnc and thats it.
cnc@debian:~/Downloads$ sudo bash ncam_debsetup.txt
[sudo] password for cnc:
Detected operating system as debian/wheezy.
Checking for curl...
Installing curl...
Reading package lists...
Building dependency tree...
Reading state information...
The following extra packages will be installed:
libcurl3
The following NEW packages will be installed:
curl libcurl3
0 upgraded, 2 newly installed, 0 to remove and 311 not upgraded.
Need to get 611 kB of archives.
After this operation, 915 kB of additional disk space will be used.
Get:1 archive.debian.org/debian-security/ wheezy/updates/main libcurl3 i386 7.26.0-1+wheezy25+deb7u1 [339 kB]
Get:2 archive.debian.org/debian-security/ wheezy/updates/main curl i386 7.26.0-1+wheezy25+deb7u1 [272 kB]
Fetched 611 kB in 1s (458 kB/s)
Selecting previously unselected package libcurl3:i386.
(Reading database ... 126431 files and directories currently installed.)
Unpacking libcurl3:i386 (from .../libcurl3_7.26.0-1+wheezy25+deb7u1_i386.deb) ...
Selecting previously unselected package curl.
Unpacking curl (from .../curl_7.26.0-1+wheezy25+deb7u1_i386.deb) ...
Processing triggers for man-db ...
Setting up libcurl3:i386 (7.26.0-1+wheezy25+deb7u1) ...
Setting up curl (7.26.0-1+wheezy25+deb7u1) ...
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done.
Importing packagecloud gpg key... done.
The repository is setup! Installing NativeCAM... done.
cnc@debian:~/Downloads$ nativecam
bash: nativecam: command not found
cnc@debian:~/Downloads$ ncam
bash: ncam: command not found
Iḿ doing something stupidly wrong but what?
Installing curl...
libcurl3
curl libcurl3
Last edit: 06 Jun 2019 17:23 by MJPfin.
- MJPfin
06 Jun 2019 19:44 #136082
by MJPfin
Somehow the deb pack wont install properly, had to run manually sudo apt-get install apt-transport-https and sudo apt-get install nativecam for it to work.
The https was the key it did not get installed for what ever reason.
After that I updated to 2.7.14 and now everything works.
Thanks guys for trying to help.
- pmconsulting
- Thank you received: 4
12 Mar 2020 20:23 #159922
by pmconsulting
Replied by pmconsulting on topic Native CAM - How To Install?
I just ran the installation per the instructions for executing the text file & installing it as a .deb.
Here's the output:
But, when I enter 'ncam' at the command prompt, I get 'Command 'ncam' not found'. Same thing if I type './ncam'.
I don't know where it is installing the program and I can't find it in Synaptic Package Manager.
Any suggestions? I'm running LinuxCNC v2.8 on Mint v19.3
Here's the output:
[sudo] password for pat:
Detected operating system as LinuxMint/tricia.
Detected curl...
The repository is setup! Installing NativeCAM... done.But, when I enter 'ncam' at the command prompt, I get 'Command 'ncam' not found'. Same thing if I type './ncam'.
- Barry
13 Mar 2020 15:47 #160031
by Barry
Replied by Barry on topic Native CAM - How To Install?
The attached procedure describes how I successfully installed NCam and embedded it in LinuxCNC. I hope this helps.
Cheers,
Barry
Cheers,
Barry
- pmconsulting
05 May 2020 05:09 #166735
by pmconsulting
Here's a PDF version of the same instructions for those who might need it:
The following user(s) said Thank You: HueyHQ
- bruno2626
- Thank you received: 3
23 Jul 2020 12:40 #175537
by bruno2626
Replied by bruno2626 on topic Native CAM - How To Install?
I can't get Nativecam installed on a new milling machine (Hurco BMC 40).
Apparently I have python installed but not python-lxml.
Python-lxml does not appear in synaptic.
I tried to install it from a deb file but some dependencies (python:any and libxml2) prevent me from doing so.
Since debian's been archived, I can't install much of anything.
What do you have in your source list file?
I've already installed nativecam for other machines but each time I'm struggling a little bit more! I don't understand much about Linux.
Thanks.
Bruno
Thanks.
Bruno
- Barry
23 Jul 2020 20:26 #175569
by Barry
Bruno, I hope someone will answer your question because I ran into the exact same problem when transferring all of my Wheezy CNC files to a new computer with a fresh installation of Wheezy this past week. I worked on it for countless hours and could not figure out how to install python-lxml. Cloning it from Get-hub is not a problem...just open a terminal and type
git clone github.com/lxml/lxml.git lxml
but then I did not have "pip" to be able to install it. So then I worked on trying to figure out how to install "pip" to be able to run....... sudo pip install lxml.
I did a lot more things and got close but could never get it to fully work. So I gave up and downloaded an iso of Debian 9.0 Stretch to a DVD and installed Stretch. Everything went very smoothly after that and I was able to quickly embed NCAM into the Linuxcnc Axis program, and my CNC was up and running again. I actually like Stretch better than Wheezy.
Note: Once you solve the python-lxml issue, the next issue is figuring out how to install gladevcp if you plan to embed NCAM into Linuxcnc Axis.
If you choose to move to Debian 9 - Stretch and want the installation directions that I documented to repeat the process if necessary, just let me know and I'll post them.
Good luck,
Barry
Good luck,
Barry
- bruno2626
24 Jul 2020 07:48 #175606
by bruno2626
Thank you for your response Barry.
I managed to install python-lxml with pip.
Indeed, now I have a gladevcp error: could not create GladeXML object.
glade-gtk2 was already installed...
So, I'll take your advice about Debian 9.0 Stretch.
Thanks.
Bruno
Thanks.
Bruno
- bruno2626
24 Jul 2020 19:48 #175668
by bruno2626
I set up Debian 9.0 Stretch found here (i386 r13):
www.linuxcnc.org/testing-stretch-rtpreempt/
I have the same error with gladevcp.
This is the 4th pc where I install nativecam, the other times were easier!
- bruno2626
25 Jul 2020 08:23 #175721
by bruno2626
I finally made it.
I had Debian 9 installed with no network. That's a bad idea.
Thanks.
Bruno
I finally made it.
Thanks.
Bruno
Time to create page: 0.436 seconds
