NativeCam on LinuxCNC 2.9.3
  • SilverRain
  • Topic Author
  • New Member
  • New Member
2 years 2 months ago - 2 years 2 months ago #307489 by SilverRain
NativeCam on LinuxCNC 2.9.3 was created by SilverRain
Удалось ли кому-нибудь установить NativeCam на LinuxCNC 2.9.3? Две недели бьюсь с проблемой Python 2.7, а теперь ругается на GTK... Сил нет.
Last edit: 2 years 2 months ago by SilverRain.
2 years 1 month ago - 2 years 1 month ago #310608 by juergen-home
Replied by juergen-home on topic NativeCam on LinuxCNC 2.9.3
I poked a bit around with linux2.9.3 and native cam. It is running, but not stable, sometimes the ncam window dissapers randomly.
Feel free to correct this list.
0. Axis 2.9.3 sim_mm running native on PC
1. download from github.com/BogdanTheGeek/NativeCAM
2. extract
3. copy to /home/cnc/linuxcnc/ncam/
4. open console in /home/cnc/linuxcnc/ncam/
5. sudo bash ncam_debsetup.txt *1
6. python3 ncam.py *2
7. sudo apt install python3-lxml
8. python3 ncam.py --> window:Create Standalone Directory /home/cnc/nativecam --> yes --> window:LinuxCNC needs to restart now --> window:NativeCam for LinuxCNC
9. python3 ncam.py --ini=/home/cnc/linuxcnc/configs/sim.axis/axis_mm.ini --catalog=mill *3
10. Start LinuxCNC --> dont start --> error (3)
11. Comment out # GLADEVCP = -U --catalog=mill /home/cnc/linuxcnc/ncam/ncam.ui in  axis_mm.ini
12. Start LinuxCNC
13.    start console in /home/cnc/linuxcnc/ncam/ python3 ncam.py -> no tool library in the tool menue
14. start again console in /home/cnc/linuxcnc/ncam/ python3 ncam.py --ini=/home/cnc/linuxcnc/configs/sim.axis/axis_mm.ini --> tool library is now avalible in tool menu-
value
*1 E: Paket nativecam kann nicht gefunden werden.
done.
ncam_debsetup.txt: Zeile 174: ncam: Kommando nicht gefunden.
*2
File "/home/cnc/linuxcnc/ncam/ncam.py", line 26, in <module>
from lxml import etree
ModuleNotFoundError: No module named 'lxml'
*3
  File "/home/cnc/linuxcnc/ncam/ncam.py", line 5942, in verify_ini
    print(_("Success in modifying inifile :\n  %s" % fname))
UnboundLocalError: cannot access local variable '_' where it is not associated with a value
During handling of the above exception, another exception occurred:
  File "/home/cnc/linuxcnc/ncam/ncam.py", line 6011, in <module>
    verify_ini(os.path.abspath(ini), catalog, in_tab)
  File "/home/cnc/linuxcnc/ncam/ncam.py", line 5946, in verify_ini
    _("Error modifying ini file\n%(err_details)s" % {"err_details": detail})
Last edit: 2 years 1 month ago by juergen-home.
The following user(s) said Thank You: freemoore
2 years 1 month ago #310616 by Giovanni
Replied by Giovanni on topic NativeCam on LinuxCNC 2.9.3
I am a beginner in Python, but I have fixed some problem (I think so) in the Bogdan's version, and I see that editing a parameter and closing the "calculator" make ncam crash cause a -11 error (segmentation fault).
I think there is something wrong related to gtk on closing dialogs.
The crash happens (on my computer) when the custom do_start_editing() function returns to the caller (I think that's gtk).
I have my modified version, if someone want to give it a try...
2 years 1 month ago #310651 by juergen-home
If you post your modified file I will give it a try.
2 years 1 month ago - 2 years 1 month ago #310660 by Giovanni
That's the file. Don't trust too much in it.
Please backup the original one and place the new one (uncompressed) in its place.
Regards
Giovanni
Edit: I see right now that the result of calculations are wrong.
They give a huge number maybe because the decimal point "." or "," in the locale.
Please insert numbers directly without any calculation.
Last edit: 2 years 1 month ago by Giovanni.
2 years 1 month ago #310711 by juergen-home
Thanks Giovanni
I'll try it next time, put it in with a long fork and a mask on :-)
Juergen
2 years 1 month ago #310764 by Giovanni
image missing /media/kunena/emoticons/smile.png
I forgot you may need the pref_edit file too.
Regards
Giovanni
2 years 1 month ago #311017 by Giovanni
Here is a more stable version (in my opinion).
But the calculation problem is still there (on my computer).
2 years 1 month ago #311080 by freemoore
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
Hello all,
It's good to see you working on NativeCAM, I use it all the time and have got to the point where I need to update to lcnc 2.9.x and the lack of ncam is the main problem.
I followed juergen-home's instructions with a couple of changes:
step 3. copied to /home/freemoore/linuxcnc/ncam/
step 4. open console in /home/freemoore/linuxcnc/ncam/NativeCAM-master
step 5. sudo bash ncam_debsetup.txt
python3 ncam.py --ini=/home/freemoore/linuxcnc/configs/sim.axis.vismach.5axis.table-rotary-tilting/xyzbc-trt.ini --catalog=mill
After this I have run each further step down to 14 and reproduced the errors and results in Juergen's post, but without getting tool library to appear in ncam.
Next I copied Giovanni's ncam.py from above in place of the one in Bogdan's download.
I still don't have a tool library, but this is outputting a program to the simulated 5-axis machine config of lcnc that I've set it up with here. And the program is running OK.
Not sure I know what would be useful to you but I'm happy to test new versions of your code here!
great to see the familiar ncam on a 2.9 installation, it gives me hope :)
cheers, Andy
Time to create page: 0.103 seconds
