NativeCam on LinuxCNC 2.9.3
22 Oct 2024 16:36 #312878 by freemoore
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
I'd be up for trying that; I've been down another rabbit-hole for the last few days and only just saw your message. What sort of medium suits you - via messages here, or e.g. whatsapp, what suits you and when?
22 Oct 2024 17:19 #312883 by Giovanni
Replied by Giovanni on topic NativeCam on LinuxCNC 2.9.3
I think that messages here would be fine.
Regards
Giovanni
23 Oct 2024 09:50 #312936 by freemoore
When would suit you?
23 Oct 2024 19:48 #312998 by Giovanni
I think we could start right now! :-)
I have written a theoretical, hypothetical installation procedure (attached below) in .pdf and editable .odt so if you need to modify it, you can.
I hope it would be useful.
Good luck. Let me know.
Regards
Giovanni
The following user(s) said Thank You: freemoore
24 Oct 2024 18:24 #313127 by freemoore
Ah great! I'll have a look.
30 Oct 2024 19:02 #313508 by Krulli_Fräser
Replied by Krulli_Fräser on topic NativeCam on LinuxCNC 2.9.3
I would love to use NativeCam in LCNC as it seems like the best way to generate easy/moderately complex gcode for directly on the control.
Modeling the part and using CAM interrupts my workflow too much.
Keep posting here when you get it to work correctly
17 Nov 2024 12:27 #314657 by freemoore
Hi Giovanni and others,
Didn't think it would take me an entire month to find time to try this, but that's what's happened. Giovanni, many thanks to you for your clear and thorough instructions, I have nativecam working embedded in a tab.
Linuxcnc version is 2.9.3.
Followed Giovanni's guide but had some issues/found solutions as follows:
I wanted to use Giovanni's latest edit of ncam.py as downloaded from p2 of this topic so extracted that to the Desktop and did:
> Desktop sudo cp ncam.py /usr/share/linuxcnc/gladevcp/NativeCAM
> Desktop sudo cp ncam.py /usr/lib/python3/dist-packages/
- I guess one of those is likely unnecessary but I'm not sure which, leaving them both there for now.
On my system there were already some lines pointing to gladevcp instead of aux_gladevcp, so where Giovanni's instructions say 'aux_gladevcp' I substituted just 'gladevcp'
I couldn't get the system to append the path: /usr/lib/python3/dist-packages/gladevcp to the pythonpath but it already contained: /usr/lib/python3/dist-packages, so instruction number 5 becomes this:
Move to the dist-packages directory:
> cd /usr/lib/python3/dist-packages
Create symbolic links to the files in the NativeCAM folder:
> sudo ln /usr/share/linuxcnc/gladevcp/NativeCAM/ncam.py -s
> sudo ln /usr/share/linuxcnc/gladevcp/NativeCAM/ncam.glade -s
> sudo ln /usr/share/linuxcnc/gladevcp/NativeCAM/pref_edit.py -s
(A few times I saw an error like 'ModuleNotFound: pref_edit.py' so added a symlink to that)
and a couple of other errors mostly due to me reading through a file too fast and putting a couple of things in the wrong place.
for no. 8: again, gladevcp instead of aux_gladevcp
I did not use instruction no. 9 as I don't use ncam as standalone.
Trying out first cuts using embedded nativecam last night, works as expected so far. No crashes as yet. Thanks also to BogdanTheGeek for the initial update!
The following user(s) said Thank You: gmouer, Clive S, COFHAL, Aciera, Giovanni
18 Nov 2024 20:36 #314798 by Giovanni
I am happy to hear that you reached the goal.
Now we could integrate your experience in the installing intructions file.
We have NativeCAM working on LinuxCNC 2.9 and 2.10 beta, Rapberry Pi and Debian.
Yes, we have to thank BogdanTheGeek for the big job of porting NativeCAM from python2 to python3.
Regards
Giovanni
The following user(s) said Thank You: gmouer, Clive S, COFHAL, Unlogic
15 Dec 2024 00:42 #316682 by COFHAL
Replied by COFHAL on topic NativeCam on LinuxCNC 2.9.3
I have LCN version 2.9.3 on Debian 12, but in /usr/share/linuxcnc/, but there is no aux_gladevcp folder, nor a folder named gladevcp.
15 Dec 2024 08:28 - 15 Dec 2024 08:51 #316693 by Giovanni
You could try to create a new path /usr/share/linuxcnc/gladevcp/NativeCAM and follow the alternative instructions given up there by freemoore since he runs LinuxCNC on Debian.
Regards
Giovanni
Last edit: 15 Dec 2024 08:51 by Giovanni. Reason: syntax
The following user(s) said Thank You: COFHAL
Time to create page: 0.253 seconds
