NativeCam on LinuxCNC 2.9.3
- SilverRain
11 Aug 2024 19:08 - 11 Aug 2024 19:10 #307489
by SilverRain
NativeCam on LinuxCNC 2.9.3 was created by SilverRain
Удалось ли кому-нибудь установить NativeCam на LinuxCNC 2.9.3? Две недели бьюсь с проблемой Python 2.7, а теперь ругается на GTK... Сил нет.
Last edit: 11 Aug 2024 19:10 by SilverRain.
- Giovanni
- Thank you received: 28
13 Aug 2024 20:16 - 17 Aug 2024 18:09 #307657
by Giovanni
Replied by Giovanni on topic NativeCam on LinuxCNC 2.9.3
I am running LinuxCNC 2.10.x (developer version) on Raspberry Pi 400.
NativeCAM forked by BogdanTheGeek forum.linuxcnc.org/nativecam/48857-fernv...ernv?start=10#292321 works, but only standalone, not in tab. I am not able to run embedded
I think it should run in LinuxCNC 2.9.3 too.
Edit: now, with some raw workaround it appears in a LinuxCNC tab. But it is not fully working.
Edit2: corrected some bugs in pref_edit.py, now it works better. I cannot update the file on GitHub.
Last edit: 17 Aug 2024 18:09 by Giovanni.
- juergen-home
- Thank you received: 15
22 Sep 2024 16:20 - 23 Sep 2024 14:10 #310608
by juergen-home
Replied by juergen-home on topic NativeCam on LinuxCNC 2.9.3
I poked a bit around with linux2.9.3 and native cam. It is running, but not stable, sometimes the ncam window dissapers randomly.
Feel free to correct this list.
0. Axis 2.9.3 sim_mm running native on PC
1. download from github.com/BogdanTheGeek/NativeCAM
2. extract
3. copy to /home/cnc/linuxcnc/ncam/
4. open console in /home/cnc/linuxcnc/ncam/
5. sudo bash ncam_debsetup.txt *1
6. python3 ncam.py *2
7. sudo apt install python3-lxml
8. python3 ncam.py --> window:Create Standalone Directory /home/cnc/nativecam --> yes --> window:LinuxCNC needs to restart now --> window:NativeCam for LinuxCNC
9. python3 ncam.py --ini=/home/cnc/linuxcnc/configs/sim.axis/axis_mm.ini --catalog=mill *3
10. Start LinuxCNC --> dont start --> error (3)
11. Comment out # GLADEVCP = -U --catalog=mill /home/cnc/linuxcnc/ncam/ncam.ui in axis_mm.ini
12. Start LinuxCNC
13. start console in /home/cnc/linuxcnc/ncam/ python3 ncam.py -> no tool library in the tool menue
14. start again console in /home/cnc/linuxcnc/ncam/ python3 ncam.py --ini=/home/cnc/linuxcnc/configs/sim.axis/axis_mm.ini --> tool library is now avalible in tool menu-
value
*1 E: Paket nativecam kann nicht gefunden werden.
done.
ncam_debsetup.txt: Zeile 174: ncam: Kommando nicht gefunden.
*2
File "/home/cnc/linuxcnc/ncam/ncam.py", line 26, in <module>
from lxml import etree
ModuleNotFoundError: No module named 'lxml'
*3
File "/home/cnc/linuxcnc/ncam/ncam.py", line 5942, in verify_ini
print(_("Success in modifying inifile :\n %s" % fname))
UnboundLocalError: cannot access local variable '_' where it is not associated with a value
During handling of the above exception, another exception occurred:
File "/home/cnc/linuxcnc/ncam/ncam.py", line 6011, in <module>
verify_ini(os.path.abspath(ini), catalog, in_tab)
File "/home/cnc/linuxcnc/ncam/ncam.py", line 5946, in verify_ini
_("Error modifying ini file\n%(err_details)s" % {"err_details": detail})
2. extract
12. Start LinuxCNC
value
done.
*2
*3
Last edit: 23 Sep 2024 14:10 by juergen-home.
The following user(s) said Thank You: freemoore
- Giovanni
22 Sep 2024 19:09 #310616
by Giovanni
I am a beginner in Python, but I have fixed some problem (I think so) in the Bogdan's version, and I see that editing a parameter and closing the "calculator" make ncam crash cause a -11 error (segmentation fault).
I think there is something wrong related to gtk on closing dialogs.
The crash happens (on my computer) when the custom do_start_editing() function returns to the caller (I think that's gtk).
I have my modified version, if someone want to give it a try...
- juergen-home
23 Sep 2024 14:13 #310651
by juergen-home
If you post your modified file I will give it a try.
- Giovanni
23 Sep 2024 16:58 - 23 Sep 2024 17:46 #310660
by Giovanni
That's the file. Don't trust too much in it.
Please backup the original one and place the new one (uncompressed) in its place.
Regards
Giovanni
Edit: I see right now that the result of calculations are wrong.
They give a huge number maybe because the decimal point "." or "," in the locale.
Please insert numbers directly without any calculation.
Regards
Giovanni
Last edit: 23 Sep 2024 17:46 by Giovanni.
- juergen-home
24 Sep 2024 14:24 #310711
by juergen-home
Thanks Giovanni
I'll try it next time, put it in with a long fork and a mask on
Juergen
Juergen
- Giovanni
25 Sep 2024 10:54 #310764
by Giovanni
- Giovanni
29 Sep 2024 09:34 #311017
by Giovanni
Here is a more stable version (in my opinion).
But the calculation problem is still there (on my computer).
- freemoore
- Thank you received: 14
30 Sep 2024 17:22 #311080
by freemoore
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
Hello all,
It's good to see you working on NativeCAM, I use it all the time and have got to the point where I need to update to lcnc 2.9.x and the lack of ncam is the main problem.
I followed juergen-home's instructions with a couple of changes:
step 3. copied to /home/freemoore/linuxcnc/ncam/
step 4. open console in /home/freemoore/linuxcnc/ncam/NativeCAM-master
step 5. sudo bash ncam_debsetup.txt
python3 ncam.py --ini=/home/freemoore/linuxcnc/configs/sim.axis.vismach.5axis.table-rotary-tilting/xyzbc-trt.ini --catalog=mill
After this I have run each further step down to 14 and reproduced the errors and results in Juergen's post, but without getting tool library to appear in ncam.
Next I copied Giovanni's ncam.py from above in place of the one in Bogdan's download.
I still don't have a tool library, but this is outputting a program to the simulated 5-axis machine config of lcnc that I've set it up with here. And the program is running OK.
Not sure I know what would be useful to you but I'm happy to test new versions of your code here!
great to see the familiar ncam on a 2.9 installation, it gives me hope
cheers, Andy
cheers, Andy
Time to create page: 0.334 seconds
