Probleme mit NativeCam
7 months 4 weeks ago #343770 by Giovanni
Replied by Giovanni on topic Probleme mit NativeCam
Here it seems to work as expected.
Could you describe the error, or attach a screenshot?
Regards
Giovanni
The following user(s) said Thank You: T_D
7 months 4 weeks ago #343778 by T_D
Replied by T_D on topic Probleme mit NativeCam
This is what i see and where the problem code accurs , could be something Wrangler with my linuxcnc or Couleur you give me some advise ?
7 months 4 weeks ago - 7 months 4 weeks ago #343780 by Giovanni
It seems that's a missing piece at the end of the file.
Let's try the attached ngc file.
Load in LinuxCNC and see if it works.
It has been generated using your ncam xml project.
Maybe you could compare it with the file which gives you the error.
Regards
Giovanni
Last edit: 7 months 4 weeks ago by Giovanni.
7 months 4 weeks ago #343783 by T_D
Thank you, i will check this when i am at home
7 months 4 weeks ago #343784 by T_D
Have you checked my ini file is this all correct or have i done a mistake
7 months 4 weeks ago #343789 by T_D
i have opened the file as an . ngc file but the same error accurs with seeking o word in line 92 what i am making wrong? please help  is there something i could try to find out what the problem is ?
Time to create page: 0.138 seconds
