Probleme mit NativeCam
7 months 4 weeks ago #343792 by T_D
Replied by T_D on topic Probleme mit NativeCam
i have found the problem , the problem was the sentence in the RS274NGC part :
[RS274NGC]
RS274NGC_STARTUP_CODE = G17 G21 G40 G43H0 G54 G64P0.005 G80 G90 G94 G97 M5 M9
# required NativeCAM item : PARAMETER_FILE = linuxcnc.var   <=HERE WAS THE FAULT I HAD WRITTEN THIS BUT THERE SHULD BE THE PLACE WHERE THE DATA SHULD BE => /Usr/linuxcnc/MY_CONFIG/........
SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities
7 months 3 weeks ago #343892 by T_D
how do i change the pref_edit.py from this one out of the forum with mine becaus when i am just copy paste than occurs an error . regards tom
The links : NativeCAM-Python3-Debian-12-Installationguide2026-02-20.pdf
: forum.linuxcnc.org/media/kunena/attachments/40714/pref_edit.py
The following user(s) said Thank You: COFHAL
7 months 3 weeks ago #344010 by Giovanni
Replied by Giovanni on topic Probleme mit NativeCam
What kind of error?
7 months 3 weeks ago #344018 by T_D
Linuxcnc wont start , how do i CPU that right ? I have no Internet connection in my Workshop thats why i have to download the file and Transfer it with a USB Stick , and when i made this an error accured
7 months 3 weeks ago #344042 by rodw
Replied by rodw on topic Probleme mit NativeCam
run linuxcnc from the command line, read the error messages and try to fix them. If you can't share the message and your config here.
Time to create page: 0.494 seconds
