Anyone beta testing Pathpilot 2.0?
8 years 11 months ago #101804 by DaOne
Any chance you could elaborate? I see you have been working on modding it as well. :) I would love to collaborate if you were interested. I have been working on the lathe side quite a bit. I wonder if Tormach has an issue with a copy?
8 years 11 months ago #101806 by sharmstr
If I were to guess, the only reason to have a beta was for the new OS and linuxcnc versions. Everything else, while great to have, wouldn't warranty beta testing. But that's just my opinion, which isnt worth much.
I'm always open for swapping code. I dont have a lathe though. You can follow my github where I post everything thats "safe" to use :) github.com/sharmstr?tab=repositories
I should have a handful of 2.0 mods up there a few days after it goes public.
The following user(s) said Thank You: Todd Zuercher, racedirector
8 years 11 months ago #101810 by DaOne
Things I have done so far are...
Fixed a few bugs
Added a tabbed status page (notebook) so I can do view all of the inputs , outputs, signals and encoders.
Added machine coordinates DROs
Added a real MPG that is switchable via the GUI as well as using the GUI step increments for the MPG (.1, .01, .001 etc)
Added HAL pins for external cycle start and feed hold pins.
Got "Classic Ladder" working.
Changed the tool changer from 8 tools to 12 and connected it with classic ladder to control a turret on a lager lathe retrofit.
Got a a fully working parallel port setup for a mini lathe with full VFD spindle control. Everything works.
Right now I am building a full new interface based on this with a larger screen resolution. I am converting based on a screen set I created years ago for Mach 3...
I would love to work on the mill side as well. I have a 1995 Haas VF-2 I will be retrofitting soon. If this interface is updated to take advantage of the new OS / linuxcnc then it will be a great building block. I would love to make it all work universally.
If you are interested you can contact me at xgenmods@gmail.com
8 years 11 months ago #101814 by sharmstr
That's impressive! I recently figured out how to add things to the PP ui. I've been mainly focusing on probing routines since there are only a handful in PP.
8 years 11 months ago #102470 by Rhine_Labs
Look's like its about to go Public cannot wait.
www.tormach.com/pathpilot2-0.html
8 years 11 months ago #102471 by DaOne
I saw that. I wonder if they will let us guys get a copy for the $20? It's gonna be a purchase (USB key) not a download.
Time to create page: 0.249 seconds
