Fitting an encoder on a Tormach 1100
8 years 7 months ago #107726 by Clive S
If I went with the 7i85 instead of the 7i75 would I be able to achieve 3 mpg's plus my spindle encoder if so what version of the 7i85 would I need to order?
8 years 7 months ago #107732 by PCW
If you used a 7I85S or 7I85 you could use the spare encoder channels as MPG inputs
or connect the 7I73 (the 7I85 has 5 sserial channels and the 7I85S has one) and get 4 MPG channels
that way. The 7I73 might simplify wiring and supports the 1X encoder mode which is usually better for 100 PPR MPG dials
8 years 7 months ago #107740 by Clive S
PCW wrote: If you used a 7I85S or 7I85 you could use the spare encoder channels as MPG inputs
Ok to re-cap I will order a 7i85s When you have time could you please make me the bit file to replace the tormach_mill3.bit and make P2 on the 5i25to be able to use the 7i85s.
Would this new one also allow me to use the 7i73 pendent if needed on the 7i85s
8 years 7 months ago #107766 by PCW
Yes a 7I85S has one SSerial channel so its possible to add a 7I73 (or any other SSerial remote device)
if you dont need more step/dir outputs you can also use a 7I85 (no s) and get 5 SSerial expansion channels
8 years 7 months ago #107772 by Clive S
PCW wrote: Yes a 7I85S has one SSerial channel so its possible to add a 7I73 (or any other SSerial remote device)
Thanks Peter for the help I will order the 7i85s and some other bits and I will await the bit file to suite.
8 years 7 months ago #107892 by Clive S
The 7i85s is now in transit to me. How do I find the correct bit file?
Time to create page: 0.439 seconds
