PathPilot 2.0.2 adding rtlib's
8 years 6 months ago #108669 by DaOne
I am desperately needing to add the missing rtlib files to pathpilot 2.0.2 such as classic ladder, mux16 etc. I am unable to build or find the correct ones. I even tried installing Linuxcnc 2.8.0-pre1-3696-gcb7d6bc onto the pathpilot mint OS to steal the files from that install. They don't work. Can anyone help me to figure this out? I had everything working under 1.9 but I would like to upgrade to 2.0.
8 years 6 months ago #108706 by emptyhb
I think it need source code to build
8 years 6 months ago #108708 by DaOne
You sure? Figured they were the same as 2.8 pre? Maybe built differentially? Anyone get the source on 2.0 yet?
8 years 6 months ago #108715 by emptyhb
Yes, I've build usercomp from 2.8 pre, load component into PP2 and it say: Shmem error. So i'm go back to 1.9
8 years 6 months ago #108716 by DaOne
Well that is a shame. I could have sworn i read someone else compiled his own module just it needed to be compiled for x64. Anyone atempted to get the 2.0 source?
8 years 6 months ago #108721 by smgvbest
use the file command on one of the rtlib files
file filename
I'm at work so dont' have access to PP but should like something like this
file libgmpxx.so.4.4.0
libgmpxx.so.4.4.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=b3b9f223f9680bb10b538432d3f0ecc37334b647, stripped
see if the rtlib file is 32 or 64 bit. you could have a mismatch in that.
you also have to be built for the same kernel so be sure your modules are built for the kernel PP is running
you'd want to build linuxcnc from source with the same realtime component that PP uses. if not that's another mismatch.
I do have a request into tormach about the source code. will see what they say
Sandra
The following user(s) said Thank You: DaOne, emptyhb
Time to create page: 0.385 seconds
