PathPilot 2.0.2 adding rtlib's
8 years 6 months ago #109480 by Stigoe
DaOne wrote: Any chance I could get you to compile these for me?
charge_pump.so
classicladder_rt.so
limit2.so
lincurve.so
mux4.so
mux8.so
xhc_hb04_util.so
Thank you in advance if you are able to help. If you are interested in editing the python code I can tell you what I did there to add external buttons.
Sure. I'll try to get it done this afternoon. I take it you're also running kernel 4.11.9-rt7 x86-64 PREEMPT?
Hopefully, I'll be able to add the needed code in the HAL-files, but if not, I'd love to know how to add buttons otherwise.
8 years 6 months ago #109498 by Stigoe
I've just sent the files to your email address. I don't know if I would be able to attach them here, so I figured email was better...
8 years 6 months ago #109499 by DaOne
Stigoe wrote: I take it you're also running kernel 4.11.9-rt7 x86-64 PREEMPT?
Whatever comes on the stock PP 2.0.x (latest version)
Thank you so much for the help on this. I got the email and will do some testing after work.
8 years 6 months ago #109545 by Stigoe
Since I can't edit my post: One thing I forgot to mention, to prevent the creation of debug-versions of the kernel, which takes a lot longer and uses a lot more space:
- Before running "make" to compile the kernel, run "scripts/configure --disable DEBUG_INFO".
8 years 6 months ago #109574 by dinkata
Please say, does it work XHC-HB04 in PathPilot 2.0 ?
What it takes to work ?
I work with config with 5i25 .
Thanks in advance !
8 years 6 months ago #109577 by DaOne
Should be the same as linuxcnc. Just add this module to the "rtlib" folder in your current install version number and edit the config file in the "configs" folder
The following user(s) said Thank You: dinkata
Time to create page: 0.181 seconds
