PathPilot 2.0.2 adding rtlib's
8 years 6 months ago #109051 by DaOne
I assume you are using the components from 1.9.x ?
8 years 6 months ago #109053 by emptyhb
DaOne wrote: I assume you are using the components from 1.9.x ?
Yes
8 years 6 months ago #109054 by DaOne
I wish you were able to explain a bit on what you did to make this happen. My email is xgenmods@gmail.com if you want to keep it private.
8 years 6 months ago #109245 by emptyhb
You can apply update UI by overwrite file, and then step by step fix problem until done!
8 years 6 months ago #109440 by Stigoe
DaOne wrote: I am desperately needing to add the missing rtlib files to pathpilot 2.0.2 such as classic ladder, mux16 etc. I am unable to build or find the correct ones. I even tried installing Linuxcnc 2.8.0-pre1-3696-gcb7d6bc onto the pathpilot mint OS to steal the files from that install. They don't work. Can anyone help me to figure this out? I had everything working under 1.9 but I would like to upgrade to 2.0.
If you're still struggling, I can tell you what I did to be able to compile at least one HAL component (toggle2nist) and getting it to work with PP2.0.2.
I installed Linux Mint 17.3 (same version PP is running) in a VM, downloaded kernel 4.11.9, patch-4.11.9-rt7 (again, same as PP 2.0.2 is running) and LinuxCNC 2.8.0 to the home folder. Following the instructions from building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel and Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb , I built kernel 4.11.9-rt7 and rebooted. I had to install quite a lot of modules to fulfill all the dendencies. When that was done, I compiled LinuxCNC, but I did not do "sudo make setuid" and rip-environment, as shown in the first post. I packed together the linuxCNC folder and copied it to my regular PathPilot install and unpacked it in /home/operator/repos/tormach_linuxcnc. After I had verified I could start PP, I tried to compile my HAL component. Just trying halcompile gave me a command not found, so I had to give the path to both halcompile and the component. In addition, I had to copy several rtapi-files over to the same directory as the component to compile. After I had copied all necessary files over, the component compiled and was copied over to ~/tmc/rtlib and I could use it in my hal-files.
Hopefully this can be of help to someone. Otherwise, all this typing has been a waste of time... :-)
The following user(s) said Thank You: Millper1
8 years 6 months ago #109466 by DaOne
That is awesome. I tried to replicate but not having any luck.
Any chance I could get you to compile these for me?
charge_pump.so
classicladder_rt.so
limit2.so
lincurve.so
mux4.so
mux8.so
xhc_hb04_util.so
Thank you in advance if you are able to help. If you are interested in editing the python code I can tell you what I did there to add external buttons.
Time to create page: 0.360 seconds
