PP 7i92/C11G problem
7 years 4 months ago - 7 years 4 months ago #137251 by PCW
Replied by PCW on topic PP 7i92/C11G problem
Did you power cycle the 7I92 card after changing the IP address jumpers?
Can you ping the 7I92 card?
You should have no red LEDs illuminated, and the Yellow power LED illuminated
and possibly some green LEDs illuminated
(the green LEDS count RX packets in the default EEPROM config)
The red LEDs should go on briefly at power up and then go off
Last edit: 7 years 4 months ago by PCW.
7 years 4 months ago #137258 by Techsavvy34
Replied by Techsavvy34 on topic PP 7i92/C11G problem
I'm gonna try a 5v 2a wall wart just to make sure that's not the issue. Yeah I power cycled the board after switching the jumpers. I'll try pinging it too. The yellow power light is on but no other lights. Is it the user leds that blink when counting rx packets?
7 years 4 months ago #137260 by PCW
If the yellow light is on, power is OK so I would not bother with a bigger supply
Do you have link lights on the Ethernet connector?
7 years 4 months ago #137429 by Techsavvy34
Thanks for all the help people but it turned out that my cat5 cable wasnt making a good connection to the contacts on my laptop. I got pathpilot upgraded now I just have to finish wiring my enclosure.
7 years 4 months ago #137817 by pl7i92
Replied by pl7i92 on topic PP 7i92/C11G problem
connection is offen a real problem on cat5
encloser
here is a example of mine
6 years 4 months ago #173308 by Techsavvy34
I'm trying to wire my vfd to the c11g to use on pathpilot. My vfd is a lenze that has start/stop, forward and reverse. I really dont need reverse so should I wire start/stop to relay 3 that is pin 1 or 17? Or could i use relay 2 which is pin 16. Thanks
Time to create page: 0.061 seconds
